 Post subject: Seagate with a lot of CRC error
PostPosted: July 25th, 2007, 10:24
Hi everyone,
this is my first message, and i want to thank you all in advance for this very interesting and helpful forum.
BTW I've a segate st3400833a recognized in bios and on device manager.
I tried with gdb, r-studio, stellar but the drive hangs and then was no more recognized.
Then I used winhex, it sees the drive phisically, gives error when try open the logical partition.
I start scanning the drive and once it gets 11% of scanning, I get a lot of cyclic redundancy error and then I lost again the drive. Just recovered 1GB of data.
And everytime does the same thing.
Any suggestions?
Thank you
 Post subject: Re: Seagate with a lot of CRC error
PostPosted: July 25th, 2007, 10:59
First of all, don't let windows play with it anymore.
Get a OS-Independant imager, and make an image to a good drive, then work from that.
CopyR, Media Tools, something like that.
PostPosted: July 25th, 2007, 12:05
Hi pcimage,
are you talking about RecoverSoft Media Tools Professional?
and what about CopyR? I cannot find it.
thank you
PostPosted: July 27th, 2007, 11:53
Try reverse cloning of the media tools. Push CRL-S and set error retries to
zero before starting the clone process.
Goodluck
PostPosted: July 27th, 2007, 12:08
Yep, Media Tools Pro.
Like pninja says, reverse mode often works better.
PostPosted: July 27th, 2007, 13:17
Copyr demo works till with 128 gb hard disk only.
DF
DF :)
www.datatracksystem.net
PostPosted: July 27th, 2007, 16:37
flabvox,
where are you based?
If UK or near, then I can help you out :-)
PostPosted: July 28th, 2007, 16:32
Hi pcimage,
I'm based in Italy...
BTW right now I've only the demo version of Recoversoft....I'm trying to get the full version....you know what I mean! :wink:
PostPosted: July 28th, 2007, 17:03
what you mean?
PostPosted: July 28th, 2007, 17:37
I think he means he doesn't want to have to pay for the software
IMHO
PostPosted: July 31st, 2007, 12:15
I surrendered!
I paid! :cry:
Ok now the situation is that the cycle clone or the reverse stops when find a read error sector.
I'm trying to set the start position on different LBA to have the more good sectors I can.
I'm figuring out what if I use HDD regenerator, because I don't think is a heads problem since I could recover some good files from the very first part of the disk.
Btw thanx all you guys for your answers and suggestions.
PostPosted: July 31st, 2007, 13:02
Ctrl-S to change setup.
Change retry from 32 to 0 or 1.
PostPosted: August 1st, 2007, 5:09
Hi pcimage,
I already set retry to 0.
The problem is that when there's a read sector error, the source drive disappears and since destination drive is on the same cable, maybe there's some conflict because after that I get even a write error and the clone ends.
Putting the destination on another cable is unuseful because always the source will disappear than there would be nothing to clone.
I tried changin' also the timeouts for read sector....I will win......perhaps! :?
PostPosted: August 1st, 2007, 5:31
Oops.
Hmm, sounds like your drive may have some pretty serious issues.
The only way forward I can think of with this, is some sort of hardware assisted imaging solution. Which has the power to soft/hard reset and pulse the power supply to the drive,when a hard error is encountered.
The only two I can think of off-hand in Data Extractor in PC3000 and Deepspar Disk Imager. There is another box that will do it, but can't think of it's name off-hand. These are all $1,000's of dollar products
I have the former two, if you want to send the drive to me I'll take a look at a very special price ;-)
Cheers
Sean
PostPosted: August 1st, 2007, 7:39
flabvox wrote:
Hi everyone,
Any suggestions?
Thank you
Hi flabvox!
PM me, maybe I can help you..
PostPosted: August 1st, 2007, 8:42
Still, you should have the source and destination on separate controllers.
PostPosted: August 9th, 2007, 8:33
Hi all,
I'm still strugglin' with this seagate, btw I wanna thank you for letting me know this great mediatool pro that helped me in other bad situations!
Cheers!
Users browsing this forum: Majestic-12 [Bot] and 190 guests
