 Post subject: Seagate terminal again
PostPosted: August 31st, 2007, 9:49
Hello!
I have made a rs232 terminal but have a problem with it. It generally works but when I try to send nearly any character it sends something totally diferent, or the letter gets dubbled. At first, I thought that it is a problem connected with windows but on linux the same thing happens. Please see the following pictures with settings of hyperterminal (com1, 8N1, flux control:none), and the weird behaviour:
Before I connect the disk (when I just open the com1 port) everything is fine, the right characters are send and printed out as echo.
Is there a way to fix this?
Any help would be very appreciated.
 Post subject: Re: Seagate terminal again
PostPosted: August 31st, 2007, 11:37
PS. I was trying to enter level 1, then leven 2, then level 3, then level T (pressed everything ONCE and just the needed symbols) and then done "zxcvbnm,./" as you can see in the last line. Tested on two diferent keyboards.
(and sorry for replying to myself but couldn't edit my post )
PostPosted: September 1st, 2007, 9:04
did u try with 2 or 3 diferrent Seagate hdd ?
is it the same ?
Spasavanje podataka
PostPosted: September 1st, 2007, 10:49
is it the same ?
It's even worse. I can't get the terminal to work with my 80Gb Seagate ST380011A. I've tried diferent speed settings and all I get is 2-6 weird characters just like the computer and drive couldn't sync. I've tried: 4800, 9600, 19200, 38400, 57600. The circuit is made accroding to the attached file but I used electrolytic capacitors instead of plain ones and used an ST232 chip. Could it be the reason for my problem?
PostPosted: September 1st, 2007, 12:19
I've asked a friend to look at the circuit and he found a "little" mistake - one of the pins was badly soldered. Now everything works fine and the other disk is responding to the terminal as well. Thank you for your advice!
Users browsing this forum: Google [Bot] and 105 guests
