 Post subject: SCSI Disk Copy Linux Debian
PostPosted: August 20th, 2007, 8:58
I will be honest (I have no idea about Linux) Here is my million dollar question :evil:
1: How can I view which disk is mapped to which device ( sd1 , hd1 etc etc)
2: I need to make sure that the disk I copy is the correct model and serial number
3: I need to copy the SCSI disk to a file on the Linux system
Any help much appreciated!
LinuxIdeot :oops:
A man is as old as he feels, and a woman as old as she looks
 Post subject: Re: SCSI Disk Copy Linux Debian
PostPosted: August 20th, 2007, 11:33
"sudo fdisk -L" displays the list of disks connected to your computer. From there you can find out which disk is connected to which device and then mount it with the "sudo mount /dev/device /mnt/where_to_mount". Furthermore if you want to find out things like serial numbers etc you can have a look at the dmesg command. It displays everthing what's going on when booting.
To copy use the cp command. Check "man cp" for further details.
rexio8
PostPosted: August 20th, 2007, 11:56
it's fdisk -l and not -L. Sorry for the mistake. And one more thing. You don't have to go through dmesg to get the serial number. There is a command "sudo hdparm -i /dev/hdX" where hdX is the device that you want to get serial number of. It can also do some other nice things. Just typing "hdparm" will give you a list of options. Tested on ubuntu 7.04 (based on debian).
PostPosted: August 21st, 2007, 5:38
Thanks for the info! :)
Dmitry
PostPosted: August 21st, 2007, 11:47
you're welcome :) Feel free to pm me or contact if you have some other problems concerning linux (but keep in mind that I'm not some kind of a linux guru.. I just use it from time to time ;)
Users browsing this forum: Google [Bot] and 101 guests
