 Post subject: N40P How to repair ????
PostPosted: October 6th, 2005, 3:20
Maxtor N40P... 6E040L0510614 AAA KMCA B8FEA 4265
Jumper In Safe mode
1. Power OFF...
2. Run Util...
3. Wait few seconds...
4. Power ON...
5. Run LDR-file loading...
Loader load successfully
6. Checking "Disk Firmware Zone" -> "Work with SA" -> "Checking of disc FM structure" & "SA surface checking"
ALL OK
7. Close Util
8. Rower OFF
jumper still in safe mode...
9. Power on
10. Run util
11. start in "standard mode"
12. while read firmware zone....display " HDD not respond in 15 second"
1. power of exit....
Repeat step 1 - 5
6 repair 4 main module [ Ulist . DMCS, Glist n Plist ]
7. power off...
8. HDD still can not start [ not respond ] in standard mode....
repeat again.. now do translator regeneration..
But the result still the sama....
HDD still can not be identified in BIOS...
Any body can help me....
How to repair this HDD....
PostPosted: October 7th, 2005, 0:59
No Body can help me ?????
PostPosted: October 7th, 2005, 2:08
I think this is a question to the PC3000 support...
 Post subject: Hot Swap
PostPosted: October 7th, 2005, 2:54
if everything fails than use hot swap.
regards
PostPosted: October 7th, 2005, 23:52
GURUDEV
THANK FOR THE ADVICE
I DONT HAVE DONOR DRIVE..... i JUST WANT TO GET THE DATA BACK....
IS IT STILL HOPE....
THANKS
 Post subject: Re: N40P How to repair ????
PostPosted: November 19th, 2005, 10:37
Jumper In Safe mode
1. Power OFF...
2. Run Util...
4. Power ON...
ALL OK
7. Close Util
8. Rower OFF
9. Power on
10. Run util
Repeat step 1 - 5
7. power off...
I have same model of HDD and same problem. What program did you use to do those things described above??? Could you please send me the programs I need to do the same things at wat3rfall2003@yahoo.co.uk. Many thanks in advance !!!
 Post subject: USE PC3000
PostPosted: November 25th, 2005, 17:02
Hi Prodata,
I can help you....
We are come from the same country.
Just call me at : 081 2241 2121.
Ok guys..
HDD is a COMPUTER...
Users browsing this forum: No registered users and 251 guests
