Safe mode
July 2nd, 2006, 11:09
Hy all people !!
Does anyone Know Safe mode setting for a SATA Maxtor Calypso 6Y120M02371BA
Thanks for all
September 16th, 2006, 6:35
See the maxtor safe mode confiquration on the pc3kisa manual
September 17th, 2006, 4:32
SATA safe mode confiquration is not present in the manual why dont u give it on the forum
Re: Safe mode
August 6th, 2007, 8:34
another unanswered question
Re: Safe mode
August 6th, 2007, 9:18
In UDMA version ACE is providing terminal for Maxtor Calypso.
DF
Re: Safe mode
August 6th, 2007, 9:39
Yes, it supplies 5v to a pin on the drive.
It's possible to make yourself too. ;-)
Re: Safe mode
August 6th, 2007, 9:41
pcimage, how to make one up?
Re: Safe mode
August 6th, 2007, 10:22
Real_Jose_Pinto wrote:pcimage, how to make one up?
You have PM.
Re: Safe mode
August 7th, 2007, 0:26
Think you could send me the info too? Thanks!
Re: Safe mode
August 7th, 2007, 9:57
Re: Safe mode
August 7th, 2007, 23:37
Starling, the safe mode does not work with Diamondmax plus 9 SATA model 6Y160M004721A
Re: Safe mode
August 8th, 2007, 9:32
Yes it does ;-)
I just tried it :-)
BTW, I made a mistake. The 5v to pin solution is for Sabre SATA, not Calypso. The one Starling states correctly is for Calypso.
Re: Safe mode
August 10th, 2007, 15:47
wat can be done to the drive when it is in safe mode?
Re: Safe mode
August 10th, 2007, 16:26
u can fix firmware problems etc.
But u DO need proper tools (i.e. PC3000, Salvation etc)
Re: Safe mode
August 11th, 2007, 14:07
also it is used for fixing hdd with bad head for eg clicking drives .
Re: Safe mode
August 23rd, 2007, 21:55
Is safe mode also called PCB mode?
Re: Safe mode
August 24th, 2007, 4:19
yep, in WD it is (Salvation products) (or "kernel" mode in PC3000)
Re: Safe mode
August 24th, 2007, 7:39
So you can make ROM changes in safe mode, but you can't make FW changes since FW changes involve writing to the SA and heads are disabled in safe mode. Is this correct?
Sorry about turning the topic slightly.
Thanks,
Andy
