 Post subject: Maxtor DiamondMax 10
PostPosted: September 13th, 2007, 6:26
I got in a Maxtor DiamondMax 10 Model 6L200M0 200GB Sata drive
Code BANC1G10 .. Bios doesn't see the drive , but Victoria sees it as
Maxtor Sabre BANC2Gxx ( I forgot the last digits, but they are
different than label) Victoria doesn't see serial number , and the LBA shows 0
When powering on the drive it "sings " to me .. A light beeping tone/noise ,
then the noise quits after a few seconds.
I don't have PC3000 .. so could this be a PCB problem , and if so ,
What do I need to match to make it work?
Thanks in advance
Steve
 Post subject: Re: Maxtor DiamondMax 10
PostPosted: September 13th, 2007, 7:22
Thanks in advance
Steve
There's your problem head mechanism error
My Forum
PostPosted: September 13th, 2007, 7:43
it is spindle seized up causing voice coil to generate magnetic field and vibrates the HGA, that's what you hear...star trek laser gun noise...you need a proff data recovery people to do platter exchange, very risky
Users browsing this forum: Google [Bot] and 99 guests
