 Post subject: HD MK4025GAS - stopped engine very slow
PostPosted: September 3rd, 2007, 16:54
Hi to all!
as I can make so that it comes back to turn and to extract the data?
Thanks for all helps!
:roll:
Нет ничего невозможного
 Post subject: Re: HD MK4025GAS - stopped engine very slow
PostPosted: September 3rd, 2007, 17:31
You can try to remove silver disk from under spindle.
Then apply lubricant and run upside-down until motor spins.
Then get data off quick!
If that does not work, then u must swap platter to good HDA.
Hope this helps.
PostPosted: September 4th, 2007, 10:04
Thanks for help pcimage!
:good:
