 Post subject: Maxtor N40P unable to load loader
PostPosted: September 10th, 2007, 1:42
Hi Friends and HDD Gurus
I have maxtor n40p , original hard disk wasn't spinning so i swapped PCB now it is showing n40p in pc3000 , with z character .
In safe mode i tried all loaders but i get error -
Error loading firmware (sector0/33 abr)
So i tried other options , and i get show technological id , but it is refusing to start utility.
What will be the best solution? Please help me.
hddbug
 Post subject: Re: Maxtor N40P unable to load loader
PostPosted: September 10th, 2007, 5:15
Did u change PCB for one with same ROM ver?
PostPosted: September 10th, 2007, 13:18
Hi PCIMAGE
Thanks , yes fortunately both pcbs are same. Both are having ardent c9-c1 microcontroller and sticker on both pcbs read B8FEA.
I dont have desoldering equipments , so could not physically change rom from source to donor . Is it because i am using wrong loaders? Please suggest me how to choose correct loader.
Hddbug
PostPosted: September 10th, 2007, 14:47
What happens with a hot swap?
PostPosted: September 10th, 2007, 22:37
When I see the N40P error I clear G-List and SMART log - that often fixes the problem.
I don't remember if the ROM makes any difference on these PCBs, but I would find a way to swap it out first, just to be sure.
http://www.datasaversllc.com
PostPosted: September 11th, 2007, 3:57
Hi Jono-ats
Thanks , in this particular case i am unable to go into the utility itself so dont have access to g-list and smart.
hddbug
Users browsing this forum: Google [Bot] and 74 guests
