 Post subject: Maxtor N40p busy state
PostPosted: September 11th, 2007, 6:30
Hi, j have a maxtor n40p which isn,t recognized in bios and in PC3000 shows busy state. j'm not solve the problem with PC3000. please help me!!! thanks in advance. :(
 Post subject: Re: Maxtor N40p busy state
PostPosted: September 11th, 2007, 9:09
what did you already try with PC3000?
PostPosted: September 11th, 2007, 13:40
j try to load a firmware and modules,try to initialize from SA and standard mode but it say- no hdd for 15sec. initalizing error.
PostPosted: September 12th, 2007, 14:47
Check if the drive is knocking or not in this case most of the times the drive is knocking .
PostPosted: September 12th, 2007, 15:52
the drive isn't knocking.
PostPosted: September 13th, 2007, 17:36
I think your replacement PCB is not compatible, try swapping ROM if they both have!
regards,
