 Post subject: QNIX file system
PostPosted: September 21st, 2007, 8:53
Someone has experience with the QNIX file system ?
What do they use ? Ext2, Ext3 or something different ?
Thanks in advance,
Dobre
Murphy was an optimist
 Post subject: Re: QNIX file system
PostPosted: September 21st, 2007, 22:14
Hello Dobre,
Do you mean QNX?
If so It has it's own individual File System. There are two versions, version 2 and version 4.
both are not compatible with each other. You should be able to compile a Linux box with QNX support in the Kernel.
Author: Frank Denis < j@4u.net> (maintainer), Richard Frowijn
Hope this helps.
PostPosted: September 22nd, 2007, 6:15
Thanks for the info. I will try.
Regards,
dobre
