 Post subject: Flickering Power in WD7500AYYS
PostPosted: November 29th, 2013, 10:35
I've got what seems to be a dying Western Digital SATA drive. It will turn on and I don't hear any evidence of physical damage (no clinking or anything like that when it's seeking) but the power seems to not be constant. What I mean by that is when a great deal of activity is going on (robocopy with 3 files copying simultaneously) or after a period of time (say 15-20 minutes of being on), you can hear the drive actually power off for a second and then come back on. Of course this intermittent power doesn't allow for much copying of data. If left alone for a while it will work for a few minutes at a time but 650+GB of data will take a while to retrieve.
So, that's what brings me here- anyone got any advice to get this data off of the drive or to repair/troubleshoot?
 Post subject: Re: Flickering Power in WD7500AYYS
PostPosted: November 29th, 2013, 10:39
You don't say what this disk is in, or the age of the PC or other details that might be relevant.
Is it possible that the PC itself is a suspect? such as a pc that is around 4-5 yrs, the capacitors on the mainboard can start to fail, and inside the power supply of the PC, can have the same issue. Google for bad capacitors in a motherboard for examples.
Also, a photo of the PCB of the HDD may help the gurus, are there any discoloration marks at all?
is there any SMART data available?
cheers
PostPosted: November 29th, 2013, 11:09
Sorry, little new to this.
I can verify it's not the PC. I've had the hard drive hooked up to multiple external enclosures with very similar if not identical results. Right now i'm working on it on a laptop hooked up to a StarTech SATDOCK22RE enclosure/duplicator.
The hard drive is getting some age on it. There is a date on it: 01 May 2008. The hard drive has been moved from one PC to another maybe in 2009 or 2010 (it was in a custom build and then moved to a Dell Inspiron Desktop). Been working fine for all that time. The thing that tipped me off that something was wrong was the HD light on the Inspiron started staying lit all the time and I pulled the hard drives one at a time until I found this one and started to figure out the above.
The outside of the drive doesn't really show any visible signs of use. There's not even any dust on it.
I don't know how to retrieve SMART data so right now, no, none available.
Any other info I can provide that would be of help I'd be glad to do.
Thanks so much.
PostPosted: November 29th, 2013, 15:57
street9009 wrote:
I don't know how to retrieve SMART data so right now ...
HD Sentinel
smartmontools
CrystalDiskInfo
HDDScan
PostPosted: November 29th, 2013, 17:56
SMART data has been added. Looks like there's one concern area (current pending errors count).
File comment: SMART data for drive
SMART.zip [4.09 KiB]
Downloaded 482 times
PostPosted: December 8th, 2013, 15:09
Forgive me since I'm new here. Is it appropriate to bump this?
PostPosted: December 8th, 2013, 15:17
Can you take the PCB off the hard drive and take a few images to post online. It might be a faulty component on the PCB thats overheating and cutting the power quickly.
Images would be helpful...
Shane
PostPosted: December 13th, 2013, 23:48
Shane
I apparently don't have the right tools to remove the PCB from the drive. Every torx screwdriver head I just tried didn't fit. So I'm not sure how to get the PCB off :-\
Spildit wrote:
Well, it can be lots of things as the Re-Lo list problem or bad PCB components or some other SA problem or heads failing ....
Can you start by trying to clone the drive using prosoft media tools ?
Try to clone the entire drive in reverse and see if you can do so.
If you are lucky you will end up with a clone and you can start working from there to recover your data.
Also do you have some tools like WDR, Salvation, etc to access SA ?
I could take a look at your drive and see if i could copy your data out using my tools and hardware but that would require for you to ship the drive to Portugal and back to you, at your expense, of course.
Best regards.
I'd be surprised if it clones the way it's acting, unless the clone software is robust enough to keep trying through the power cycling it's doing. I'll give it a shot, though. Can't hurt for sure. I've never used WDR or Salvation. How do they work?
PostPosted: December 14th, 2013, 13:03
Most likely you drive is RAID Edition 2 (RE2) and belongs to Jupiter-Zuma family. The drive is 4-platter, 8-head monster that becomes hot very rapidly. When reaches a critical temperature of about 55 degree C it stops and waits to cool down.
All you need is a fan blowing at the drive.
And you have to clear all pending sectors, of course.
PostPosted: December 17th, 2013, 20:44
It doesn't appear to wait very long. It does seem to be when it's been on a while but that said when it gets "hot" (or whatever it is getting), it only powers off for a split second, then back on, and off, and on, and off.... definite yo-yo effect. I've tried putting it in the freezer to keep it cooler so it would last longer but that doesn't seem to have any effect. Not sure keeping it cool is the problem but I am an admitted novice.
How do you clear pending sectors?
PostPosted: December 17th, 2013, 22:17
Can you provide some images of the PCB board, more than likely some component is getting too hot. If you provide some images of the PCB board we can go on from there.
PostPosted: December 17th, 2013, 22:20
I can't remove it but I can take pictures of the outside? I apparently don't have the right screwdriver to fit the screws on it :-\
PostPosted: December 18th, 2013, 1:59
a Torx screwdriver set should be less than $10 at a hobbyist electronics store such as radioshack/tandy/dick smith/jaycar or ebay. You don't need an expensive one. You could even take it to your local neighborly pc repair shop/ electronics and ask them to unscrew it, I am sure they wouldn't mind.
in the interim, you can take a pic of the exposed side but more than likely the important side is hidden.
sorry, you are going to have to solve the torx issue ;)
PostPosted: December 21st, 2013, 11:43
Well that's the thing. I have several Torx screwdriver heads (I've got one of those screwdrivers that comes with about 40 different heads you can switch out when needed) but none of them will grip. Guess I can take the drive with me to the store and make sure something they have fits.
PostPosted: December 21st, 2013, 22:52
I know what you mean I have several kits and many sizes are skipped in between.
PostPosted: December 23rd, 2013, 0:40
Good clone software is designed just for that. It will keep track of what has been cloned and keep chunking away at it till its done
PostPosted: December 23rd, 2013, 1:10
Hi, It would be helpful for a few examples of good cloning software that does this.. Cheers
PostPosted: December 23rd, 2013, 18:30
Yes, please! That would be extremely helpful.
PostPosted: December 23rd, 2013, 22:38
ddrescue is a great free choice. You would have to baby sit the drive and restart it manually.
http://www.technibble.com/forums/showthread.php?t=48269
PostPosted: August 31st, 2014, 17:42
So yea it's been a while but I finally got a picture of the underside. It's attached to this post.
I also had another thought and wanted to run it by you- I have two of these hard drives and the other is still working fine. Is it worth the effort to back that one up, then swap these boards to see if the bad one will fire up to get the data off of it as well?
Appreciate any insight and thank you for what's already been shared.
File comment: Picture of underside of PCB board.
Users browsing this forum: No registered users and 66 guests
