 Post subject: WD5000KS
PostPosted: February 9th, 2008, 11:28
my disk is
WD 5000KS
WD CAVIAR SE 16
MDL:WD5000KS-00MNB0
DATE 17 SEP 2006
DCM:HCACAJAH
PCB
2061-701383-E00 AG XS 3H18 3MNX 5 0001100 7101
donors
WD 5000KS
WD CAVIAR SE 16
MDL:WD5000KS-00MNB0
DATE 08 SEP 2006
DCM:HCACAJAH
PCB
2061-701383-E00 AG XS 3H18 205U 6 0006080 7086
when i was copying data from one disk to wd5000ks system froze..i did a reset and from then my disk appears to controller screen(jmicron)but windows cant boot with that disk connected...when i disconect the disk its ok
i managed to find a similar disk to swap pcb but it doesnt work,it doesnt even show at controlers screen(with its own pcb at least i can see the disk as a name on jmicron screen)
i was hopping that if i had a donor that similar i was going to work just fine
any ideas?
 Post subject: Re: WD5000KS
PostPosted: February 9th, 2008, 21:24
These look really close. I don't remember if these have embedded ROMs or not. If there is a separate ROM, I would try to swap it. Failing that, I'd do a hotswap.
Jon
http://www.datasaversllc.com
PostPosted: February 10th, 2008, 5:07
is it possible to be the heads that have the problem?because pcb's so intetical should do the work(they have the same DCM so no changing rom needed),
is that right?
PostPosted: February 10th, 2008, 16:59
is that right?
The heads probably are bad. We've seen others in this series with bad heads and mechanicals.
But before I condemn them, I do everything else I can to be more certain. For example, I am working on a WD2500 and recovering data from 5 of the 6 heads. It is a clicker. I gained access to the LBA doing a hotswap. The donor drive isn't anywhere close to the subject drive (different part number) but they are of the same family (Hawk). Apparently, they are close enough to use. So I would think yours would be as close as practical and they should work, all things being equal.
Nonetheless, if there is a different head map (located in ROM) then clicking can occur, and that's why I would eliminate the ROM as a possible culprit.
Jon
Users browsing this forum: Austinblake22 and 43 guests
