 Post subject: Wanted, ROM for an WD2000JB-00HBB0
PostPosted: October 16th, 2007, 12:40
Do any one have ROM for this WD2000JB-00HBB0, DCM: DSBHCTJAH.
I need this specific match because my clients ROM-Chip is blown.
The odd thing is that the only thing on that Pcb that's faulty is the ROM-Chip, if I replace the chip it works flawless.
And is there another way to make this drive alive again, beside an exactly match?
Bosse
http://www.rescue-it.se
 Post subject: Re: Wanted, ROM for an WD2000JB-00HBB0
PostPosted: October 16th, 2007, 13:53
HB should be SATA. Are you sure it's not JD?
What's your email?
PostPosted: October 17th, 2007, 11:09
Hi Starling, thanks for the ROM.
Of course you're right..shuld be JD...Drive is now sorted, an little update for you all of the solution:
The drive was completly dead.changed Pcb, drive spinns up, but knocked....so I then know that the fault was in the Pcb.
Tryed to read out the ROM, no contact with Pcb in safe mode either....tryed to read it out with soic-clip and external programmer, got a lot of errors....like over current and so.
Desolder the chip, and put on a donar Pcb....drive stone dead again???
So I delsolder the chip again put on my desk and took my external programmer with soic-clip...2 tries and error....third time BINGO...got the bin file out.
Took another donar Pcb, and reprogrammed the chip and the drive fired up ;-)
Then I put it in with MediaTools Pro and did a clone fast as possible....worked well, phoned up a very happy client.
He got photos from 2002...and no backup.....so now I think he will get one quick as hell ;-)
Bosse
Users browsing this forum: napalm_atx and 118 guests
