 Post subject: Read/Write module ID into HDD WD to recover old serial and m
PostPosted: October 14th, 2007, 22:04
hi all,
i can read Module ID by PC3000, Data in module is serial number and model
but i can't write data into module ID, module ID can be locked. after that, i reset HDD, serial and model display wrongly on PC300 .
Serial number: WDC-ROM SN#XYZ----
Model: WDC ROM MODEL--SABRE--
what do i do to recover old serial and model? can everyone help me? thanks
 Post subject: Re: Read/Write module ID into HDD WD to recover old serial and m
PostPosted: October 15th, 2007, 1:09
Where do you live?
I can help you if you live in Vietnam :good:
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: October 15th, 2007, 1:57
hi Hddlab,
i'm glad to meet you!! I'm a Vietnamese. I'm living in HCM city. where do you live in Viet Nam?
Do you know the ways to write data into Module ID to recover serial and model? we can share knowledge about this problem together.
thanks,
muoimuoi
PostPosted: October 15th, 2007, 2:37
muoimuoi wrote:
hi Hddlab,
I'm glad to meet you!! I'm a Vietnamese. I'm living in HCM city. where do you live in Viet Nam?
i used Pc 3000 to write data into module ID of new Hdd. After that i reset hdd, serial number and model display wrongly on Pc3000. you can see data at attach file when i read Module ID.
i write data which contain old serial and model into module ID again, after that i reset HDD again, serial and model still display wrongly on Pc 3000.
Serial and model will be always displayed:
serial:WDC-ROM SN#XYZ
model:WDC ROM MODEL--SABRE---
Please tell me ways to recover old serial and model!!
thanks,
muoimuoi
PostPosted: October 15th, 2007, 3:42
Do you have the real PC3000 card? If you using PC3K from China's clone, it can not be done many work. I'm living in Hanoi-Vietnam. Nice to meet you here!
PostPosted: October 15th, 2007, 4:26
yes, i have a PC3000 card.
I'm using it from Russia, not from China's clone. it have done many work for me.
but when i write data into module ID, it's not support to me this problem
perhaps, you have used Pc3000 and you have more experience.
what do you have good ideal to recover serial number and model?
please help me,
thanks,
muoimuoi
PostPosted: October 15th, 2007, 8:03
Firt of all, you need to check what is problem? Is your drive klicking?
Rất vui gặp bạn ở đây, Việt Nam anh hùng phết nhể :D , trước tôi cứ nghĩ cả VN có mỗi tôi với một cậu nữa dùng hàng xịn còn toàn đồ tầu, nay lại thêm bạn. Bạn tên gì? PC3000 Card number? Nick của bạn trong Acelab forum là gì? Tôi có đủ hết cả bộ của Acelab, bạn có những gì?
PostPosted: October 15th, 2007, 10:28
Hi, nice topic for VNM
@ Repair_ HDD Recover DATA @
Add: Gác 2 Số 10 Hàng Bè Hà Nội Việt Nam
Đặc biệt: Cứu dữ liệu trong trường hợp ổ cứng chết Cơ.
Website: http://www.repair-hdd.com
Tel : 9177619-9263400
PostPosted: October 15th, 2007, 11:13
Yes, very nice :D
PostPosted: October 15th, 2007, 12:08
Did you swap the PCB? Seems like yours is not original.
PostPosted: October 15th, 2007, 22:03
hi all,
i have two kind of WD hdd: Marvell and Caviar.
for Marvell, i write data into module ID and recover serial and model correctly on Card PC3000.
but i can't recover serial and model for Caviar HDD on Card PC3000 because command write data into module ID's Caviar not correctly.
Việt Nam anh Hùng có thể giúp tôi được không!
i want myself recover serial and model by PC3000, i can't take my hdd to Recovery data company.
pls hepl me,
thanks
muoimuoi
PostPosted: October 16th, 2007, 15:22
Before "recovering S/N" you should fix your drive first.
In your case it's either ROM is not original or some overlays in SA are corrupted. After you fix your drive S/N will show up correctly.
PostPosted: October 17th, 2007, 0:18
hi Starling,
do you know MDT hard disk drive? is it different with WD hard disk drive?
i have some MDT hard disk drive, i wrote data into module ID and there are some change into module ID. Serial and Model is wrong. Now, i want to recover serial and model by the way is write data into module ID. But serial and model is always wrong same as "muoimuoi"!
your ideal is good, i have just done but i don't recover.
thanks
PostPosted: October 18th, 2007, 3:22
hi,
when i check module ID, PC 3000 report Module ID error.
so i can't recover serial number and model. what reason does module ID make error?
do you know the ways to repair Module ID on PC 3000?
pls show me!!
thanks
muoimuoi
PostPosted: October 18th, 2007, 4:44
hi all,
i have just checked module ID again on PC 3000, Copy 0 and Copy 1 into module ID error.
can you show me the way to repair copy 0 and copy 1?
thanks
muoimuoi
PostPosted: October 18th, 2007, 8:05
Copy from Copy 0 and write to Copy 1 or vice versa .
Users browsing this forum: Google [Bot] and 50 guests
