 Post subject: Segate 7200.10 PCB required.........Thanks!!
PostPosted: October 22nd, 2007, 12:50
Got an odd one here, a 7200.10 that does not spin. Just get a quiet high-pitched whine from the PCB when power is applied.
The PCB does the same on another drive.
Another (although not 100% compatible) PCB spins up the drive, but cannot load App Code, which I expect.
I have tested the voltage lines through to the motor connection points, and voltage is getting there, although it seems a little high (~6.5 - 6.8v).
So, I need a PCB...
Model: ST332060A
F/W: 3.AAC
ROm Code: 100404195
Many thanks in advance.
Sean
 Post subject: Re: Segate 7200.10 PCB required.........Thanks!!
PostPosted: October 23rd, 2007, 10:24
Or suggestions how I can fix the PCB?
Users browsing this forum: Google [Bot] and 181 guests
