 Post subject: Pattern in MHDD Scan results
PostPosted: October 25th, 2007, 8:49
I'm running MHDD on a Thinkpad R40e with Fujitsu MHT2030AT drive. I'm 10% into the scan and I am seeing a patten of equally spaced results, alternating between <10ms and >500ms. I am trying to determine whether it is worth replacing the hard drive or if this may indicate a controller problem. The CD drive is also not recognized which makes me suspect a controller problem. Can anyone clarify what I'm seeing in the scan results? Thanks.
 Post subject: Re: Pattern in MHDD Scan results
PostPosted: October 25th, 2007, 12:56
Most likely one of the heads is degrading.
But I would run a scan on another desktop computer rather than a laptop just to be sure.
Users browsing this forum: Majestic-12 [Bot] and 247 guests
