 Post subject: Maxtor DiamondMax Plus 9 160GB SATA/150 HDD
PostPosted: November 11th, 2007, 21:57
My backup disk, wich was properly cooled and powered by Thermaltake PSU 450W, Maxtor DiamondMax Plus 9 160GB SATA/150 HDD with sn: Y48KJA7E 6Y160M00469AB AAA manifacturing date february 2005 and made in Singapore
sudenly after power lack of 30mins failed to respond. Agere , samsung cache memory and SMOOTH chip are there and on serial ata plug there is a M8818030-TBC
It behave like this: when I boot machine it is recognised by the bios perfectly and when windows start to loading my computer stay on same place as long as it is powered.
I would like to know some methods first software than hardware how i could sick datas from it and put it then on some wall as suvenir. Until then my eyes are red, there are so much painly colected pro software and some always lost family stafs.....
Thank you to all who can help me!
 Post subject: Re: Maxtor DiamondMax Plus 9 160GB SATA/150 HDD
PostPosted: November 11th, 2007, 22:47
I would download knoppix from here http://www.knopper.net burn the ISO to CD and boot your computer with it. You should have new media ready to copy the data off. It sounds like possible file system corruption, and can be relatively easy to recover your data
Shawn
PostPosted: November 12th, 2007, 1:18
And if you are not familiar with Linux (Knoppix) you can put the driva into another computer (friends, mom,dad) and copy your files over to that harddrive.
When you're done just put your drive back in your computer and reinstall your system.
As Shawn said, it's probably just a logical failure in your filesystem, and your data should be fully intact.
http://www.rescue-it.se
PostPosted: November 13th, 2007, 19:50
actualy i tryed on linux mandriva, win2003 server and winxp, also i have knopix will try with it, but things are worst than you predicted. I cant boot windows when that hd is conected and linux cant mount it. Will try first with Easy Recovery PRO what you say ?
PostPosted: November 14th, 2007, 3:21
Hi
I would wote for cloning that disk first, then use a logical recovery soft.
PostPosted: November 14th, 2007, 4:02
4fuxsake,
you come here --. the home of fantastic MHDD - Free diagnostic tool,
and you work with BIOS and Windows and knoppix and all kinds of other sh#t.
BIOS, Windows and all that cr#p don't give you diagnostics.
MHDD Diagnostics give you some answers
use MHDD and report then people can help you better :wink:
Users browsing this forum: No registered users and 123 guests
