 Post subject: Maxtor 6B250R0061211 Firmware Help
PostPosted: November 16th, 2007, 9:19
Need firmware for either PC3000 PCI or HDD Doctor for Maxtor By Salvation Data
Maxtor Sabre
6B250R0061211
CODE BAH41BM0
KGCA
SN B619B1VH
Thank you.
 Post subject: Re: Maxtor 6B250R0061211 Firmware Help
PostPosted: November 27th, 2007, 19:49
SA structure test
Selected family ........................... SABRE
Model ..................................... Maxtor 6B250R0
Firmware .................................. BAH41BM0
Serial .................................... B619B1VH
Min. cylinder ............................. 1082
Max. cylinder ............................. 104431
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 29
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Checksum .................................. Error
Serial number ............................. B619B1VH
Max LBA ................................... 490234752
Head number ............................... 6
Head map .................................. 0 1 2 3 4 5
SA head map ............................... 0 1 2 3 4 5
Model1 ............................... Maxtor 6B300R0
Max LBA .............................. 586114704
Model2 ...............................
Max LBA .............................. 0
Model3 ............................... Maxtor 6B250R0
Max LBA .............................. 490234752
Model4 ...............................
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV8 ü
Checking User data adaptives
Header .................................... CR0T?¯
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 1082: 7567: 1224
2 : 7568: 14052: 1200
3 : 14053: 20537: 1152
4 : 20538: 27022: 1152
5 : 27023: 33507: 1109
6 : 33508: 39992: 1075
7 : 39993: 46477: 1042
8 : 46478: 52962: 1008
9 : 52963: 59447: 960
10 : 59448: 65932: 932
11 : 65933: 72417: 896
12 : 72418: 78902: 848
13 : 78903: 85387: 800
14 : 85388: 91872: 748
15 : 91873: 98357: 696
16 : 98358: 104431: 645
17 : 104451: 104567: 384
Checking ROM Copy
Check sum Value ........................... 7F49
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 0000
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... 00..
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
OverlayId ................................. 0018
OverlayId ................................. 0019
OverlayId ................................. 001A
OverlayId ................................. 001B
OverlayId ................................. 001C
OverlayId ................................. 001D
OverlayId ................................. 001E
OverlayId ................................. 001F
OverlayId ................................. 0020
OverlayId ................................. 0021
OverlayId ................................. 0022
OverlayId ................................. 0023
OverlayId ................................. 0024
OverlayId ................................. 0025
OverlayId ................................. 0026
OverlayId ................................. 0027
OverlayId ................................. 0028
OverlayId ................................. 0029
OverlayId ................................. 002A
OverlayId ................................. 002B
OverlayId ................................. 002C
Checking RZTbl
Checking P-List
Checking G-List
Checking G-List copy
Checking RZTbl-PList
Difference ................................ not found
Checking RZTbl-HList
Beg.Cyl. End Cyl. :Def.count Def.count (PList)
1083 - 1083 :0 / 7340
1085 - 1085 :0 / 7340
1087 - 1087 :0 / 7340
1089 - 1089 :0 / 7340
1091 - 1091 :0 / 7340
1093 - 1093 :0 / 7340
1095 - 1095 :0 / 7340
1097 - 1097 :0 / 7340
1099 - 1099 :0 / 7340
1101 - 1101 :0 / 7340
9023 - 9023 :0 / 7165
9030 - 9031 :0 / 14330
9036 - 9037 :0 / 14330
9041 - 9041 :0 / 7165
9952 - 9952 :0 / 7165
15776 - 15776 :0 / 6988
15785 - 15785 :0 / 6988
19714 - 19718 :0 / 34940
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 800
Block1
Header .................................... UHRS0010
Defect Count .............................. 799
Block2
Header .................................... UHRS0020
Defect Count .............................. 798
Block3
Header .................................... UHRS0030
Defect Count .............................. 146
Checking security
Header .................................... SECU
User Password ............................. "********************************"
Master Password ........................... "********************************"
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking FMTI
Id ........................................ 93
Header .................................... Ok
Checking [DISK/PW]
not found
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 ................................. Ok
Module 19 ................................. Ok
Module 1A ................................. Ok
Module 1B ................................. Ok
Module 1C ................................. Ok
Module 1D ................................. Ok
Module 1E ................................. Ok
Module 1F ................................. Ok
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. Ok
Module 24 ................................. Ok
Module 25 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. Ok
Module 30 ................................. Ok
Module 32 ................................. Ok
Module 33 ................................. Ok
Module 34 ................................. Ok
Module 37 ................................. Ok
Module 38 ................................. Ok
Module 39 ................................. Ok
Module 3A ................................. Ok
Module 3B ................................. Ok
Module 3C ................................. Ok
Module 3D ................................. Ok
Module 41 ................................. Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 ................................. Ok
Module 45 ................................. Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E ................................. Ok
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. Ok
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. Ok
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 6E ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 ................................. Ok
Module 79 ................................. Ok
Module 7A ................................. Ok
Module 7B ................................. Ok
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8C ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 90 ................................. Ok
Module 92 ................................. Ok
Module 93 ................................. Ok
Module 94 ................................. Ok
Module 96 ................................. Ok
Module 97 ................................. Ok
Module 98 ................................. Ok
Module 99 ................................. Ok
Module 9A ................................. Ok
Module 9B ................................. Ok
Module 9C ................................. Ok
Module 9D ................................. Ok
Module 9E ................................. Ok
Module 9F ................................. Ok
Module A0 ................................. Ok
Module A1 ................................. Ok
Module A2 ................................. Ok
Module A5 ................................. Ok
Module A6 ................................. Ok
Module A7 ................................. Ok
Module A9 ................................. Ok
Module AA ................................. Ok
Module AB ................................. Ok
Module AC ................................. Ok
Module AD ................................. Ok
Module AE ................................. Ok
Module AF ................................. Ok
Module B0 ................................. Ok
Module B1 ................................. Ok
Module B2 ................................. Ok
Module B6 ................................. Ok
Module C0 ................................. Ok
Module C1 ................................. Ok
Module CB ................................. Ok
Module CC ................................. Ok
THIS IS THE REPORT I GOT ANY HELP PLEASE...
PostPosted: November 30th, 2007, 11:18
ANY FIRMWARE OR SUGGESTIONS??
PostPosted: November 30th, 2007, 12:54
So what's the problem? :)
SA looks fine.
PostPosted: November 30th, 2007, 16:24
There looks like a CS error in the "DISK" module, that's all I can see wrong.
PostPosted: November 30th, 2007, 21:16
Would the CS error cause the drive not to have the data readable? The drive detects but cant get to the data.
PostPosted: December 3rd, 2007, 14:23
That's not a professional way to describe your problem. Especially if you have PC3000.
Start scanning the surface with Express test and notice what errors you get.
Users browsing this forum: Google [Bot] and 92 guests
