 Post subject: Recovery Help Needed
PostPosted: November 18th, 2007, 4:33
I was setting up a new wd500gb hdd and had to erase the partition and used wd tools for writing zero's to the drive and accidently did the wrong drive. Ya I know Stupid. Thats what I get for working on this when I'm tired. Anyhow the drive that was zeroed has 5 partions on it. I have tried Active Partition Recovery and it shows it can recover 4 of the partions but the primary partition c isn't showing up as the software has a 4 partition limit. well it is saying the drive does. Since it can image a partition, I am thing of recovering them 1 at a time but not sure if I can drive C back.
is there better software to do a recovery of the partitions and data?
 Post subject: Re: Recovery Help Needed
PostPosted: November 18th, 2007, 10:10
I was the quick erase used so it did the first & last million sectors.
The drive is a wd 80 GB.
PostPosted: November 18th, 2007, 14:26
I assume that this drive has Windows Data on it?
Have you tried R-Studio on it? They've just released a new verions.
How about Boomerang?
http://www.datasaversllc.com
PostPosted: November 18th, 2007, 15:20
Yes it does, there are 6 logical partitions, 1 linux & 1 linux ext on it which appear to be recoverable however I am not seeing the primary partition. I have it hooked up as a single/master on the secondary ide slot on another pc. It was a master drive in the original pc. just removed the master with slave jumper since there is no need for the slave drive.
I have tried 2 apps so far to look at it to see what they could do recovering it.
PDTT Partition Table Doctor shows 6 fat32 logical partitions, 1 linux & 1 linux ext.
Active Partition Recovery shows the 6 fat32 partitions.
I have R-Sudio 4 network edition. will that work?
any ideas on the number of partitions on the drive affecting recovery?
Since there is already a primary c drive on the 2nd pc. would that cause the recovery software to only see the logical partitions on this drive?
PostPosted: November 28th, 2007, 22:34
Active Partition Recovery recovered all the partitions.
used a recent backup of the OS. Very minor data loss from the last backup. ran scandisk in windows and no errors on any partitions.
Lucked out on this one.
Users browsing this forum: No registered users and 76 guests
