 Post subject: Maxtor 3005b Sata2 MFT problem
PostPosted: November 24th, 2007, 9:23
Recently my WD250 died and i gave it back to the schop and got my self maxtor 500gb sata 2 STM3500630AS Firmware 3.AA
I started to notice some strange things(movies, pictures... were corrupted) So I run chkdsk /f, and goterrors in MFT and index entry in file 25. No mater ho many times i run chkdsk /f errors keep coming up. So I borrowed WD passport250(FAT32), and copied most of the data, formated HD using HDD Low Level Format Tool, it keep reporting errors but after it has finished I format it with windows, and restored data, this is what I got today:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Windows\system32>e:
E:\>chkdsk
The type of the file system is NTFS.
WARNING!  F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
  22272 file records processed.
File verification completed.
  0 large file records processed.
  0 bad file records processed.
  0 EA records processed.
  0 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
An index entry from index $O of file 25 is incorrect.ocessed)
Errors found.  CHKDSK cannot continue in read-only mode.
E:\>chkdsk  /f
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process.  Chkdsk may run if this volume is dismounted first.
ALL OPENED HANDLES TO THIS VOLUME WOULD THEN BE INVALID.
Would you like to force a dismount on this volume? (Y/N) y
Volume dismounted.  All opened handles to this volume are now invalid.
Deleted invalid filename P_SETU|1.RES (11784) in directory 11751.
Correcting minor file name errors in file 11784.
Fixing incorrect information in file record segment 14979.ed)
Correcting minor file name errors in file 14979.
Deleted invalid filename fin2,blp (18178) in directory 18169.
File 18178 has been orphaned since all its filenames were invalid
Windows will recover the file in the orphan recovery phase.
Correcting minor file name errors in file 18178.
Correcting minor file name errors in file 21377.es processed)
Deleting an index entry from index $O of file 25.s processed)
An unspecified error occurred.
E:\>chkdsk  /f
Deleting corrupt attribute record (48, "")records processed)
from file record segment 11784.
Deleting corrupt attribute record (128, "")
from file record segment 14979.
Deleting corrupt attribute record (128, "")ecords processed)
from file record segment 18178.
from file record segment 21378.
Inserting an index entry into index $O of file 25.
Deleting index entry P_SETUPWIZARD.res in index $I30 of file 11751.
Deleting index entry P_SETU~1.RES in index $I30 of file 11751.
Deleting index entry Bone Mirror in index $I30 of file 14977.
Deleting index entry BONEMI~1 in index $I30 of file 14977.
Deleting index entry fin2.bmp in index $I30 of file 18169.ed)
Deleting index entry 06 Track 6.mp3 in index $I30 of file 21371.
Deleting index entry 06TRAC~1.MP3 in index $I30 of file 21371.
  25592 index entries processed.
Index verification completed.
CHKDSK is recovering lost files.
  49 unindexed files processed.
Recovering orphaned file 06 Track 6.mp3 (21377) into directory file 21371.
CHKDSK is verifying security descriptors (stage 3 of 3)...
  22272 security descriptors processed.
Security descriptor verification completed.
Inserting data attribute into file 11784.
Inserting data attribute into file 14979.
Inserting data attribute into file 18178.
Inserting data attribute into file 21378.
  1664 data files processed.
Correcting errors in the master file table's (MFT) BITMAP attribute.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
488253439 KB total disk space.
  92210096 KB in 20578 files.
     12116 KB in 1664 indexes.
         0 KB in bad sectors.
    103123 KB in use by the system.
     65536 KB occupied by the log file.
395928104 KB available on disk.
      4096 bytes in each allocation unit.
122063359 total allocation units on disk.
  98982026 allocation units available on disk.
E:\>chkdsk  /f
Deleting corrupt attribute record (16777280, "")s processed)
from file record segment 19269.
Correcting error in index $O for file 25.x entries processed)
Deleting index entry ik_addgoal1.tif in index $I30 of file 14996.
Deleting index entry IK_ADD~2.TIF in index $I30 of file 14996.
Deleting index entry dialogs in index $I30 of file 18914.sed)
Deleting index entry Jelena Karleusa - Ludaca (cela).mp3 in index $I30 of file 1
9052.
  25596 index entries processed.
Recovering orphaned file IK_ADD~2.TIF (15003) into directory file 14996.
Recovering orphaned file ik_addgoal1.tif (15003) into directory file 14996.
Recovering orphaned file dialogs (18916) into directory file 18914.
Recovering orphaned file Jemena Karleusa - Ludaca (cela).mp3 (19269) into direct
ory file 19052.
  47 unindexed files processed.
  1662 data files processed.
  92210096 KB in 20582 files.
E:\>
No mater how many times i check it, it cames up with errors. Btw smart and all other test came up ok.
Does anybody have any solution?
PS: My mainboard: ASUS P5ND2 SLI nforce 4 intel]
 Post subject: Re: Maxtor 3005b Sata2 MFT problem
PostPosted: November 24th, 2007, 9:45
Hi nnn,
Try to run MHDD on that disk. Use Scan. I assume it will find bad sectors.
Please let us know what MHDD reports.
Regards,
Dobre
Murphy was an optimist
PostPosted: November 24th, 2007, 9:48
I scaned whole disk surface(not with MHDD btw but with HDDScan it lasted Whole night and found no bad sectors.
PostPosted: November 24th, 2007, 17:45
I scaned it with MHDD, no bad sectors 90% were beneath 3ms
Users browsing this forum: Google [Bot] and 81 guests
