 Post subject: WD Marvell SA modules description
PostPosted: November 29th, 2007, 17:39
does anybody knows the description for WD Marvell based chips drives SA modules?
Like for WD chips based drives module 25=translator and so on.
Especially the module nr.11. What is inside this module? I have corrupted module 11 on WD400BB-00FJA0 and i am not sure if i can use other drive's module to replace.
Kib
 Post subject: Re: WD Marvell SA modules description
PostPosted: November 29th, 2007, 22:27
Module 11h is ATA overlay
you can use it from other drive but you need to match revision
PostPosted: November 30th, 2007, 3:45
Thank you Doomer. Do you happen to have module 11 for WD400BB-00FJA0 FW 13.03G13 ? There is a revision 1350 in the header of other modules.
Thank you
Kib
Users browsing this forum: Google [Bot] and 101 guests
