 Post subject: maxtor n40p defect list
PostPosted: December 3rd, 2007, 3:11
i have maxtor n40p. before this it can't detect serial no & fw. i do step by step to detect back the serial no & fw & success.run SA test, all modules ok except rztbl Hlist error. i try to do regenerate translator but still have that error..& i always found this error when i repair the maxtor..so what should i do to clear rztbl Hlist error?
any help is much appreciated..
thanks
 Post subject: Re: maxtor n40p defect list
PostPosted: December 3rd, 2007, 14:08
This is not an error.
SA in your case most likely is fine, it's just your drive has a lot of bad sectors probably.
PostPosted: December 3rd, 2007, 22:45
hi starling,
thanks for the reply. so if it just bad sector, i will try erase using mhdd.
one more thing i need to ask. i always found error - wrong module id "93" when run SA test. is this error also just bad sector or error in certain module? can it be fixed or not?
thanks
Users browsing this forum: No registered users and 101 guests
