 Post subject: Diamond Max 10, 300G power surged destroy all data?
PostPosted: December 5th, 2007, 2:15
Hi Guys
I have Maxtor Diamond Max 10 Model 6L300R0, power surged the detroyed few diodes, after changing few parts now the drive spin up and detected, checked all modules ok except RZBTL-HList few errors.
I could not access the data, i tried Rstudio, MTL, etc could not see the data, any ideas what could be wrong here?
Thank's in advance.
 Post subject: Re: Diamond Max 10, 300G power surged destroy all data?
PostPosted: December 5th, 2007, 4:47
Mostly, with this drive some RZTBL -Hlist errors is normal,
and don't impact on data integrity.
MHDD ?
PostPosted: December 5th, 2007, 5:30
mhdd scan 2 bad sectors, all good but could not get the data, very strange... :roll:
PostPosted: December 5th, 2007, 10:05
Hello terranova if u are using anothe PCB, maybe its not the Same FW version of u Original ROM by this way the HDD reach DRDY DSC but when use the command to read sectors show´s 00 00 i had a case similar like u same model 6L300RO , and was caused by this problem .
Best Regards
PostPosted: December 5th, 2007, 11:07
Are you sure you are looking for the right file system?
Did you try recovery by file signatures(aka raw recovery)?
PostPosted: December 5th, 2007, 22:16
Beto, I used old pcb, Starling, raw recovery under DE the hdd keep power off and power on not going anywhere.
Under Rstudio, Rstudio hang and i have to power on and off.
PostPosted: December 10th, 2007, 21:30
Surface test (Physical), too many AMN errors, any hope?
PostPosted: December 11th, 2007, 12:45
So, you didn't even make an image? :?
PostPosted: December 11th, 2007, 20:07
Hi Starling, could not image drive, AMN error throughout
PostPosted: December 12th, 2007, 10:15
no image - no love.
do you mean you have AMNF in every sector?
try to find good board first.
PostPosted: December 12th, 2007, 10:42
Could the board be bad if all modules are good? :roll:
PostPosted: December 25th, 2007, 21:30
Thank you all for your response.
I'm having a hard time troubleshooting this drive, anyone have any clue please?
Here's the result of Diagnostic using UDMA (please dont mind the long pages)
Thank's again.
SA structure test
Selected family ........................... SABRE
Model ..................................... Maxtor 6B300R0
Firmware .................................. BAH41B70
Serial .................................... B617JNAH
Min. cylinder ............................. 1082
Max. cylinder ............................. 104431
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 10
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Checksum .................................. Error
Serial number ............................. B617JNAH
Max LBA ................................... 586114704
Head number ............................... 6
Head map .................................. 0 1 2 3 4 5
SA head map ............................... 0 1 2 3 4 5
Model1 ............................... Maxtor 6B300R0
Max LBA .............................. 586114704
Model2 ...............................
Max LBA .............................. 0
Model3 ............................... Maxtor 6B250R0
Max LBA .............................. 490234752
Model4 ...............................
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV8½û
Checking User data adaptives
Header .................................... CR0T–Ÿ
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 1082: 7567: 1258
2 : 7568: 14052: 1228
3 : 14053: 20537: 1200
4 : 20538: 27022: 1152
5 : 27023: 33507: 1132
6 : 33508: 39992: 1104
7 : 39993: 46477: 1069
8 : 46478: 52962: 1036
9 : 52963: 59447: 998
10 : 59448: 65932: 960
11 : 65933: 72417: 917
12 : 72418: 78902: 864
13 : 78903: 85387: 822
14 : 85388: 91872: 768
15 : 91873: 98357: 713
16 : 98358: 104431: 658
17 : 104451: 104567: 384
Checking ROM Copy
Check sum Value ........................... 81E7
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 0000
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... 00..
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
OverlayId ................................. 0018
OverlayId ................................. 0019
OverlayId ................................. 001A
OverlayId ................................. 001B
OverlayId ................................. 001C
OverlayId ................................. 001D
OverlayId ................................. 001E
OverlayId ................................. 001F
OverlayId ................................. 0020
OverlayId ................................. 0021
OverlayId ................................. 0022
OverlayId ................................. 0023
OverlayId ................................. 0024
OverlayId ................................. 0025
OverlayId ................................. 0026
OverlayId ................................. 0027
OverlayId ................................. 0028
OverlayId ................................. 0029
OverlayId ................................. 002A
OverlayId ................................. 002B
OverlayId ................................. 002C
Checking RZTbl
Checking P-List
Checking G-List
Checking G-List copy
Checking RZTbl-PList
Difference ................................ not found
Checking RZTbl-HList
Beg.Cyl. End Cyl. def.count Def.count (PList)
1082 - 1223 :4064 / 4096
25893 - 26045 :0 / 30
26046 - 26198 :0 / 38
26199 - 26351 :0 / 2304
26811 - 26963 :0 / 2304
27023 - 27180 :0 / 1
27181 - 27338 :0 / 4
27339 - 27496 :0 / 2266
27497 - 27654 :0 / 2264
28129 - 28286 :0 / 2
28761 - 28918 :0 / 2264
29077 - 29234 :0 / 81
29393 - 29550 :0 / 90
30183 - 30340 :0 / 3
30341 - 30498 :0 / 2
30657 - 30814 :0 / 2264
31131 - 31288 :0 / 4529
31289 - 31446 :0 / 1
31921 - 32078 :0 / 6585
32553 - 32710 :0 / 4
33670 - 33831 :0 / 1
33994 - 34155 :0 / 1
34156 - 34317 :0 / 2208
34318 - 34479 :0 / 98
34480 - 34641 :0 / 1
34966 - 35127 :0 / 4416
35290 - 35451 :0 / 296
35614 - 35775 :0 / 1
35776 - 35937 :0 / 50838
35938 - 36099 :0 / 2208
36100 - 36261 :0 / 1
36262 - 36423 :0 / 290
36586 - 36747 :0 / 2
36748 - 36909 :0 / 1
37234 - 37395 :0 / 1
37396 - 37557 :0 / 2208
37558 - 37719 :0 / 2208
37720 - 37881 :0 / 2209
37882 - 38043 :0 / 1
38692 - 38853 :0 / 8832
39016 - 39177 :0 / 146
39178 - 39339 :0 / 2289
39502 - 39663 :0 / 164
39664 - 39825 :0 / 4417
39993 - 40159 :0 / 2138
40160 - 40326 :0 / 284
40327 - 40493 :0 / 6387
40828 - 40994 :0 / 2754
41162 - 41328 :0 / 1
41663 - 41829 :0 / 80
41830 - 41996 :0 / 1
41997 - 42163 :0 / 2138
42164 - 42330 :0 / 2138
42498 - 42664 :0 / 2
42832 - 42998 :0 / 2138
42999 - 43165 :0 / 2141
43500 - 43666 :0 / 1
43834 - 44000 :0 / 5420
44502 - 44668 :0 / 2426
44836 - 45002 :0 / 78
45170 - 45336 :0 / 2138
45504 - 45670 :0 / 3282
46651 - 46823 :0 / 3
47343 - 47515 :0 / 2072
47516 - 47688 :0 / 4144
47862 - 48034 :0 / 2
48208 - 48380 :0 / 6
49592 - 49764 :0 / 2072
49765 - 49937 :0 / 2073
50284 - 50456 :0 / 1
50803 - 50975 :0 / 2072
50976 - 51148 :0 / 2112
51668 - 51840 :0 / 2085
51841 - 52013 :0 / 1668
52187 - 52359 :0 / 2072
52360 - 52532 :0 / 2072
52533 - 52705 :0 / 1
52963 - 53141 :0 / 300
53142 - 53320 :0 / 74
53500 - 53678 :0 / 1996
53679 - 53857 :0 / 1
53858 - 54036 :0 / 1
54037 - 54215 :0 / 3920
54395 - 54573 :0 / 1
55111 - 55289 :0 / 1
55290 - 55468 :0 / 2
55648 - 55826 :0 / 274
56722 - 56900 :0 / 2
57796 - 57974 :0 / 1996
58512 - 58690 :0 / 1
59049 - 59227 :0 / 3
59228 - 59406 :0 / 3
59820 - 60005 :0 / 1920
60378 - 60563 :0 / 1920
60936 - 61121 :0 / 3
61308 - 61493 :0 / 2
61494 - 61679 :0 / 1920
61680 - 61865 :0 / 88
61866 - 62051 :0 / 960
62238 - 62423 :0 / 2
65028 - 65213 :0 / 1
65214 - 65399 :0 / 1
65586 - 65771 :0 / 960
65933 - 66128 :0 / 2
67893 - 68088 :0 / 1
68089 - 68284 :0 / 917
68481 - 68676 :0 / 68
68677 - 68872 :0 / 930
68873 - 69068 :0 / 1
69265 - 69460 :0 / 917
69657 - 69852 :0 / 1
69853 - 70048 :0 / 1
70049 - 70244 :0 / 80
70637 - 70832 :0 / 917
71029 - 71224 :0 / 1
71617 - 71812 :0 / 1
72624 - 72829 :0 / 1
73242 - 73447 :0 / 864
75096 - 75301 :0 / 3
75920 - 76125 :0 / 78
76332 - 76537 :0 / 1
77362 - 77567 :0 / 1
78186 - 78391 :0 / 1
78804 - 78902 :0 / 1728
78903 - 79120 :0 / 2
79557 - 79774 :0 / 1
80211 - 80428 :0 / 1
80647 - 80864 :0 / 1
81519 - 81736 :0 / 80
81955 - 82172 :0 / 1
82173 - 82390 :0 / 1
82827 - 83044 :0 / 78
83045 - 83262 :0 / 1
84353 - 84570 :0 / 1
84571 - 84788 :0 / 2
84789 - 85006 :0 / 3
85225 - 85387 :0 / 88
87252 - 87484 :0 / 1
87951 - 88183 :0 / 3
88184 - 88416 :0 / 84
88883 - 89115 :0 / 1
89582 - 89814 :0 / 1
90747 - 90979 :0 / 2
92124 - 92374 :0 / 1
92375 - 92625 :0 / 1
92626 - 92876 :0 / 1
93630 - 93880 :0 / 1
94634 - 94884 :0 / 1
95387 - 95637 :0 / 81
95638 - 95888 :0 / 1
95889 - 96139 :0 / 1
96391 - 96641 :0 / 1
96642 - 96892 :0 / 2
97144 - 97394 :0 / 4
97395 - 97645 :0 / 3
97646 - 97896 :0 / 2
97897 - 98147 :0 / 1
98148 - 98357 :0 / 3
98630 - 98901 :0 / 1
99174 - 99445 :0 / 1
99446 - 99717 :0 / 1
99718 - 99989 :0 / 1
99990 - 100261 :0 / 2
100534 - 100805 :0 / 3
101078 - 101349 :0 / 1
101350 - 101621 :0 / 2
101622 - 101893 :0 / 1
102438 - 102709 :0 / 1
102710 - 102981 :0 / 1
102982 - 103253 :0 / 1
103526 - 103797 :0 / 2
103798 - 104069 :0 / 1
104070 - 104341 :0 / 1
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 4
Block1
Header .................................... UHRS0010
Defect Count .............................. 797
Block2
Header .................................... UHRS0020
Defect Count .............................. 192
Checking security
Header .................................... SECU
User Password ............................. "********************************"
Master Password ........................... "Maxtor*INIT SECURITY TEST STEP*F"
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking FMTI
Id ........................................ 93
Header .................................... Ok
Checking [DISK/PW]
not found
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 Copy0 ........................... Ok
Module 18 Copy1 ........................... Ok
Module 19 Copy0 ........................... Ok
Module 19 Copy1 ........................... Ok
Module 1A Copy0 ........................... Ok
Module 1A Copy1 ........................... Ok
Module 1B Copy0 ........................... Ok
Module 1B Copy1 ........................... Ok
Module 1C Copy0 ........................... Ok
Module 1C Copy1 ........................... Ok
Module 1D Copy0 ........................... Ok
Module 1D Copy1 ........................... Ok
Module 1E Copy0 ........................... Ok
Module 1E Copy1 ........................... Ok
Module 1F Copy0 ........................... Ok
Module 1F Copy1 ........................... Ok
Module 20 Copy0 ........................... Ok
Module 20 Copy1 ........................... Ok
Module 21 Copy0 ........................... Ok
Module 21 Copy1 ........................... Ok
Module 22 Copy0 ........................... Ok
Module 22 Copy1 ........................... Ok
Module 24 ................................. Ok
Module 25 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F Copy0 ........................... Ok
Module 2F Copy1 ........................... Ok
Module 30 Copy0 ........................... Ok
Module 30 Copy1 ........................... Ok
Module 32 Copy0 ........................... Ok
Module 32 Copy1 ........................... Ok
Module 33 ................................. Ok
Module 34 Copy0 ........................... Ok
Module 34 Copy1 ........................... Ok
Module 37 Copy0 ........................... Ok
Module 37 Copy1 ........................... Ok
Module 38 Copy0 ........................... Ok
Module 38 Copy1 ........................... Ok
Module 39 Copy0 ........................... Ok
Module 39 Copy1 ........................... Ok
Module 3A ................................. Ok
Module 3B ................................. Ok
Module 3C ................................. Ok
Module 3D ................................. Ok
Module 41 Copy0 ........................... Ok
Module 41 Copy1 ........................... Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 Copy0 ........................... Ok
Module 44 Copy1 ........................... Ok
Module 45 Copy0 ........................... Ok
Module 45 Copy1 ........................... Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 Copy0 ........................... Ok
Module 48 Copy1 ........................... Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F Copy0 ........................... Ok
Module 4F Copy1 ........................... Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E Copy0 ........................... Ok
Module 5E Copy1 ........................... Ok
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 Copy0 ........................... Ok
Module 63 Copy1 ........................... Ok
Module 64 Copy0 ........................... Ok
Module 64 Copy1 ........................... Ok
Module 65 Copy0 ........................... Ok
Module 65 Copy1 ........................... Ok
Module 66 Copy0 ........................... Ok
Module 66 Copy1 ........................... Ok
Module 67 Copy0 ........................... Ok
Module 67 Copy1 ........................... Ok
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 6E ................................. Ok
Module 70 Copy0 ........................... Ok
Module 70 Copy1 ........................... Ok
Module 71 Copy0 ........................... Ok
Module 71 Copy1 ........................... Ok
Module 72 Copy0 ........................... Ok
Module 72 Copy1 ........................... Ok
Module 73 Copy0 ........................... Ok
Module 73 Copy1 ........................... Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 Copy0 ........................... Ok
Module 78 Copy1 ........................... Ok
Module 79 ................................. Ok
Module 7A Copy0 ........................... Ok
Module 7A Copy1 ........................... Ok
Module 7B Copy0 ........................... Ok
Module 7B Copy1 ........................... Ok
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8C ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 90 ................................. Ok
Module 92 ................................. Ok
Module 93 Copy0 ........................... Ok
Module 93 Copy1 ........................... Ok
Module 94 Copy0 ........................... Ok
Module 94 Copy1 ........................... Ok
Module 96 Copy0 ........................... Ok
Module 96 Copy1 ........................... Ok
Module 97 Copy0 ........................... Ok
Module 97 Copy1 ........................... Ok
Module 98 Copy0 ........................... Ok
Module 98 Copy1 ........................... Ok
Module 99 Copy0 ........................... Ok
Module 99 Copy1 ........................... Ok
Module 9A Copy0 ........................... Ok
Module 9A Copy1 ........................... Ok
Module 9B ................................. Ok
Module 9C ................................. Ok
Module 9D ................................. Ok
Module 9E Copy0 ........................... Ok
Module 9E Copy1 ........................... Ok
Module 9F ................................. Ok
Module A0 ................................. Ok
Module A1 ................................. Ok
Module A2 ................................. Ok
Module A5 Copy0 ........................... Ok
Module A5 Copy1 ........................... Ok
Module A6 Copy0 ........................... Ok
Module A6 Copy1 ........................... Ok
Module A7 ................................. Ok
Module A9 ................................. Ok
Module AA ................................. Ok
Module AB ................................. Ok
Module AC ................................. Ok
Module AD ................................. Ok
Module AE ................................. Ok
Module AF Copy0 ........................... Ok
Module AF Copy1 ........................... Ok
Module B0 ................................. Ok
Module B1 ................................. Ok
Module B2 ................................. Ok
Module B6 ................................. Ok
Module C0 ................................. Ok
Module C1 ................................. Ok
Module CB ................................. Ok
Module CC ................................. Ok
Module FF Copy0 ........................... Ok
Module FF Copy1 ........................... Ok
SA surface verification
Zone Id ................................... 0
Start UBA ............................ 8
Size ................................. 2 400
Errors .................................... 0
Zone Id ................................... 1
Start UBA ............................ 2 408
Size ................................. 4 416
Zone Id ................................... 2
Start UBA ............................ 8 922
Size ................................. 4 800
Zone Id ................................... 3
Start UBA ............................ 13 722
Size ................................. 4 700
Zone Id ................................... 4
Start UBA ............................ 18 422
Size ................................. 500
Zone Id ................................... 5
Start UBA ............................ 6 824
Size ................................. 2 098
Zone Id ................................... 6
Start UBA ............................ 19 008
Zone Id ................................... 7
Start UBA ............................ 21 408
Zone Id ................................... 8
Start UBA ............................ 0
Size ................................. 8
Zone Id ................................... 9
Start UBA ............................ 42 600
Test completed
Users browsing this forum: No registered users and 100 guests
