 Post subject: Hitachi travelstar IN25N030ATMR04-0
PostPosted: January 3rd, 2008, 6:57
Hi forum
has anyone experineced an issue with the above drive.
initial issue was drive was clicking all the time, obtained a rerplacement drive and relpaceds heads and small 8 pin chip so i have the original drive with donor heads and 8 pin chip, when it is attached to the pc3000 i am now getting 2 clicks and then the below.
i am truly lost and am tyying to get this sorted but gettting nowhere. i am lost as to what is happening.
i have worked on a fujitsu 30gb which showed all faulty modules, i replaced the heads and all data was recovered but this drive is beyond me as to what is happeninig.
is it possible that a drive cant be recovered even with the pc3000 and data extractor?
thank you for any help
Selected family......................... : ATMR
Model by ID............................. : <ID IS NOT READ>
Techno mode key......................... : Ok
NV-RAM reading.......................... : Ok
Module not read (RESF)
Error : Device error detected (ABR)
Loading modules table................................................. : Error
Error :............................................................... : Module not read (RESF)
Loading the table of "open" modules................................... : Error
Error :............................................................... : Error executing loading "open" modules dir command
Module ZONE is not found!
Module is not loaded (RESF, Main module table)
Test : HDD resources backup
Folder: D:\Unwired\dead drive modules
Reading ROM to file (ROM\ROM.bin)..................................... : Ok
Reading NV-RAM to file (NV-RAM\NV-RAM.nvr)............................ : Ok
Off-line start resources
Reading modules to profile folder
Folder: D:\Unwired\dead drive modules\Modules\
Module RSVD Copy 0...................... : Ok
Module RSVD Copy 1...................... : Ok
Module RSVD Copy F...................... : Ok
Module RESF Copy 0...................... : Ok
Module RESF Copy 1...................... : Ok
Module RESF Copy F...................... : Ok
Modules reading completed
Saving modules by copies.............................................. : Ok
Saving SA report to file SAReport_0_1_F.txt
Module checking
Module RAM0 is not found!
Module not created! RAM0
Module OVR0 is not found!
Module not created! OVR0
Module OVR1 is not found!
Module not created! OVR1
Module IDNT is not found!
Module not created! IDNT
Module CNS1 is not found!
Module not created! CNS1
Module MLBA is not found!
Module not created! MLBA
Module PIDM is not found!
Module not created! PIDM
Module not created! ZONE
Module RDMT is not found!
Module not created! RDMT
Module MFGP is not found!
Module not created! MFGP
Reading modules to profile folder (composite)
Module not read (RSVD)
Error : Device error detected (UNC)
Error : Device error detected (INF)
Module RSVD............................. : Error
Error : ModStg: composite reading impossible - reading error!
Module RESF............................. : Error
Saving modules (composite)............................................ : Error
Backup of service information completed
 Post subject: Re: Hitachi travelstar IN25N030ATMR04-0
PostPosted: January 3rd, 2008, 7:45
Why have you changed the 8-pin Chip?
This NVRAM pertains to the SA data on the platters, and is not related to the heads
PostPosted: January 3rd, 2008, 8:21
Hi Pcimage,
thank you for the reply.
i posted a question to the ace forum and was advised to try that hence i changed the nvram chip.
when i had the original chip on the original board so only item changed was the heads frmo the donor to the original faulty drive the drive still mkept on clicking.
i guess my question should then be do i need to restore the original chip to the original board and then start from there again?
Thank you
Ari
PostPosted: January 9th, 2008, 3:22
Well, SalvationDATA HD Doctor for IBM/Hitachi, it can solve the NVRAM problem.
Repair NVRAM: Repair the NVRAM (no matter just part of it is damaged or the whole NVRAM is damaged). This function is very important in data recovery and there is no other tool capable for this job except our tool.
If you are interested in the products, please contact me.
Best Regards
Laura Lee
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
Users browsing this forum: Google [Bot], shubhsinghal and 51 guests
