 Post subject: WD1600 and pc3000
PostPosted: December 12th, 2007, 6:18
Hi all
i have a small question regarind a wd1600 and PC3000, basically the drive shows up in windows when installed as a slave, cant access the partition says it is not formatted.
DE in Pc3000 has recovered the information simply so that is all ok, i have done the tests to try and diagnose the issue and why it does not work with the pc 3000 with the attached results all showing ok except
"Configuration loading................... : HDD has configuration module version : "021C?" in the SA test.
Any ideas on how to proceed and where the error lies will be greatly apreciated.
Data has already been recovered.
thx
wd 1600.txt [14.17 KiB]
Downloaded 571 times
Users browsing this forum: No registered users and 73 guests
