 Post subject: Hitachi ATMR
PostPosted: December 15th, 2007, 0:58
This particular hard disk is a Hitachi Travelstar IC25N020ATMR04-0 rev A00 .
I tried DE but not able to get anything
Is there anyway to recover data?
Selected family......................... : ATMR
Model by ID............................. : <ID IS NOT READ>
Module is not loaded (RESF, Main module table)
NV-RAM reading........................................... ............. : Ok
Loading module table............................................. ..... : Error
Error :................................................. .............. : Module not read
Loading the table of "open" modules................................... : Error
Error :................................................. .............. : Error executing loading "open" modules dir command
Module ZONE is not found!
Test : HDD resources backup
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\ATMR\atmr\Data\SABackup\
Reading ROM to file (ROM\ROM.bin)..................................... : Ok
Reading NV-RAM to file (NV-RAM\NV-RAM.nvr)............................ : Ok
Off-Line
Reserved SA copy : main
Reading modules to profile folder
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\ATMR\atmr\Data\SABackup\Modules\
Reading module ID RSVD.............................................. .. : Error
Error : Module not read
Reading module ID RESF.............................................. .. : Error
Modules reading process completed
Result............................................ .................... : Error
Saving SA report to file SAReport.txt
ROM ID.................................. : AD0A
NV-RAM ID............................... : AD0A
RESF version............................ : <ERROR!>
Active SA copy.......................... : main
Module checking
Report about module RESF, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Loaded.................................. : No
ID ABA ABA(Orig.) Len(S) Len(B) Addr in RAM Read Header Importn. Description
RSVD : 7FD20000 : 7FD20000 : 3 : 1536 : 00000000 : No : : B : SA marker
RESF : 7FE20000 : 7FE20000 : 2 : 1024 : 00000000 : No : : B : Main module table
Modules checking process completed
Module not loaded! ID = RSVD; SA marker
Error : Module is not loaded (RSVD, SA marker)
Module IDNT is not found!
Module not created! IDNT
Module CNS1 is not found!
Module not created! CNS1
Module MLBA is not found!
Module not created! MLBA
Module PIDM is not found!
Module not created! PIDM
Module not created! ZONE
Module MFGP is not found!
Module not created! MFGP
Reserved SA copy : factorial
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\ATMR\atmr\Data\SABackup\Modules_FCT\
Saving SA report to file SAReport_FCT.txt
Active SA copy.......................... : factorial
Module checking
RSVD : 7FD00000 : 7FD20000 : 3 : 1536 : 00000000 : No : : B : SA marker
RESF : 7FE00000 : 7FE20000 : 2 : 1024 : 00000000 : No : : B : Main module table
Backup of service information completed
 Post subject: Re: Hitachi ATMR
PostPosted: December 15th, 2007, 8:17
it is possible U are facing with head related problem.
try starting the util by loading config from DB.
and see if U can read any other modules. If not, try replacing heads.
PostPosted: December 15th, 2007, 8:36
Is the drive spinning up?
Is it making any unusual noises?
PostPosted: December 16th, 2007, 0:38
thank you pepe sir,
I will try to load modules from database and report back.
Thank you
PostPosted: December 16th, 2007, 0:48
Hi pcimage , yes drive is spinning like normal drive without any abnormal sound .As per Pepe sir's suggestion i will try to load from DB
Users browsing this forum: Google [Bot] and 48 guests
