 Post subject: D540X-4K Head Replacement
PostPosted: December 18th, 2007, 1:19
Does anyone know what identifying numbers I need for a successful head transplant on a D540X-4K? This drive seems to be half Maxtor and half Quantum. I found a LE06A011-01-B but I'm not sure if its compatable. Thanks.
D540X-4k
GTLA: LE06A011-01-A
P/N: MX4K060H3
P/N 1: JP-012342-12541-16U-12U4
CT: 246B60055M1UR0
P/N 3: 11S06P5331ZJ1H9T3HEU14
FRU: 19K1581
S/N: 373117925924
 Post subject: Re: D540X-4K Head Replacement
PostPosted: December 18th, 2007, 14:23
this one is tricky, it is almost impossible to find a fully compatible MHA due to the different alignment positions of the heads.
All u can do is to match at least the first letter of the code bellow the serial number and hope or align the heads.
PostPosted: March 16th, 2008, 1:13
Ok. I transplanted the donor heads into the failed drive but now I have a new problem. The heads go from center to outer edge three times then stay on the outer edge. After that it reports ready but does not ID. Before the transplant I could read from head 0 and 2 but not 1. Any ideas? Thanks.
PostPosted: March 17th, 2008, 2:40
this is what I call head misalignment... with 60G it is pretty hard to get them aligned.
PostPosted: March 17th, 2008, 3:00
The donor was spot on as far as identification numbers and all. In fact, the serials are really close. Do you have any advise on aligning the heads? Thanks.
PostPosted: March 17th, 2008, 7:59
Ho There ,
Ask Pep sir About the Head Alignment Issue ,I Will Try To Find The Exact Numbers For you I Have 100 of These Drives even Pepe Sir Might Remember that .
PostPosted: March 17th, 2008, 22:19
Failed Drive: DGPXX
Donor Drive: DGZXX
PostPosted: March 19th, 2008, 11:11
What kind of clicking it had originally? Ding-ding-spinfaster-spinslower-ding-ding-ding? If yes then it's usually bad preamp and it's much easier to just swap it and keep the original heads.
PostPosted: March 19th, 2008, 14:15
Never clicked, just could not read from head 1. 0 and 2 work fine in DE.
Users browsing this forum: No registered users and 65 guests
