 Post subject: Samsung burn code
PostPosted: December 22nd, 2007, 9:12
Hello all,
I need burn in code and main code of QP200-03 , QP200-05 and QP100-07 if someone has please share .
Thanks in advance .
 Post subject: Re: Samsung burn code
PostPosted: December 29th, 2007, 5:16
hi
I am also in serch of ht code for samsung puma if u get please do share and mean while i wll also try to get burn code for you
PostPosted: December 29th, 2007, 13:15
Hey Rameez, where had you lost man? Didn't see you from ages. Didn't smell you on the messenger too. Still searching for those Samsung Codes? Let me know the specifications of your drives. By the details you provided, I can only figure out that they are Victor-SV4002H. Meet me at messenger, and come up with the specifications for the need, there could be some stuff for ya.............
Without furthur details, all I can give till now is this:- :D
File comment: File Contains Codes for V40 QP200-03 , QP200-05 and QP100-07.
SV4002H Codes.rar [178.5 KiB]
Downloaded 444 times
To Richa_Kapur,
Dude, same stuff for you, the details? "PUMA" just doesn't hit the point. And, why do you "specifically" need the Hardware Test Codes? As it is actually by and for the Samsung's manufacturing units. Are you sure, it's not the "Burn-in" or "Main" code? :?
harddiskbug@yahoo.com
PostPosted: December 31st, 2007, 14:06
Thankyou for all your replys i have found all the burn in codes for samsung i also have PUMA resources i will check out if it has the HT code or not , but it is in pc3k pci database format .
Users browsing this forum: Google [Bot] and 70 guests
