 Post subject: MK4021GAS Command Abort..
PostPosted: December 31st, 2007, 7:37
hello all ,
I am having a problem with Toshiba MK4021GAS drive.
it intialze propely ,detected in mhdd.
TOSHIBA MK4021GAS LBA: 78,140,160
SN: Y2FN0564T FW: GA224C
On pressing scan (F4) it show all command abort error till the end of disk.i have checked security,but it is not on. Password is not set in drive.
HDD: TOSHIBA MK4021GAS; FW: GA224C; SN: GA224C
Name Val Worst Raw
Att # 1 : Read error rate : 100 100 0
Att # 2 : Throughput performance : 100 100 0
Att # 3 : Spin up time : 100 100 1236
Att # 4 : Number of spin-up times : 100 100 3908
Att # 5 : Reallocated sectors count : 82 82 859
Att # 7 : Seek error rate : 100 100 0
Att # 8 : Seek time performance : 100 100 0
Att # 9 : Power-on time : 73 73 11029
Att # 10 : Spin-up retries : 177 100 0
Att # 12 : Start/stop count : 100 100 1903
Att # 192 : Power-off retract count : 100 100 104
Att # 193 : Load/unload cycle count : 59 59 416043
Att # 194 : HDA Temperature : 100 100 27
Att # 196 : Reallocate event count : 100 100 178
Att # 197 : Current pending sectors : 100 100 0
Att # 198 : Offline scan UNC sectors : 100 100 0
Att # 199 : Ultra ATA CRC Error Rate : 200 253 0
Att # 220 : Disk shift : 100 100 187
Att # 222 : Loaded hours : 84 84 6723
Att # 223 : Load retry count : 100 100 0
Att # 224 : Load friction : 100 100 0
Att # 226 : Load-in time : 100 100 390
Att # 240 : Unknown : 100 100 0
this is smart attributes.
hpa commands are also show command abort errors.
Please help in this by suggest the right way for datarecovery..
I will be very thanks full.
Thanks and regards
 Post subject: Re: MK4021GAS Command Abort..
PostPosted: December 31st, 2007, 8:23
Maybe the g-list is full or corrupt?
Clear it
PostPosted: December 31st, 2007, 8:43
is it safe for DR? and Smart must be bad for G-list full as i think.
What do you say.?
Thanks for quick reply
PostPosted: December 31st, 2007, 13:21
backup module if possible first.
Good DR should be possible, but not 100% perfect.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 121 guests
