 Post subject: WD 800BB
PostPosted: January 9th, 2008, 15:59
Hello friend´s and hddguru´s
I want u opinion about this case WD800BB on first shows DRDY DSC not knock sound , but when u tried to access any sector show´s ABRT , this is the SA Report and the progress
Techno mode key:
Tech on................................. : Ok
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
Head number reading..................... : Ok
Heads number............................ : 2
ROM:
ROM reading............................. : Ok
Heads number in use..................... : 2
Switched off heads...................... : No
Head map................................ : 0,1
Service area:
SA dir reading.......................... : Ok (Copy 0)
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
Heads test
Cylinder to test........................ : -50
Heads to test........................... : 0,1
Head 0.................................. : List index out of bounds (0)
Head 1.................................. : List index out of bounds (0)
SA structure test
Module 01 Copy 0........................ : Ok
Module 01 Copy 1........................ : Ok
Module 17 Copy 0........................ : Ok
Module 17 Copy 1........................ : Ok
Module 1B Copy 0........................ : Ok
Module 1B Copy 1........................ : Ok
Module 4C Copy 0........................ : Ok
Module 4C Copy 1........................ : Ok
Module 13 Copy 0........................ : Ok
Module 13 Copy 1........................ : Ok
Module 11 Copy 0........................ : Ok
Module 11 Copy 1........................ : Ok
Module 35 Copy 0........................ : Ok
Module 35 Copy 1........................ : Ok
Module 02 Copy 0........................ : Ok
Module 02 Copy 1........................ : Ok
Module 33 Copy 0........................ : Ok
Module 33 Copy 1........................ : Ok
Module 34 Copy 0........................ : Ok
Module 34 Copy 1........................ : Ok
Module 15 Copy 0........................ : Ok
Module 15 Copy 1........................ : Ok
Module 1E Copy 0........................ : Ok
Module 1E Copy 1........................ : Ok
Module 12 Copy 0........................ : Ok
Module 12 Copy 1........................ : Ok
Module 1C Copy 0........................ : Ok
Module 1C Copy 1........................ : Ok
Module 31 Copy 0........................ : Ok
Module 31 Copy 1........................ : Ok
Module 32 Copy 0........................ : Ok
Module 32 Copy 1........................ : Ok
Module 50 Copy 0........................ : Ok
Module 50 Copy 1........................ : Ok
Module 51 Copy 0........................ : Ok
Module 51 Copy 1........................ : Ok
Module 52 Copy 0........................ : Ok
Module 52 Copy 1........................ : Ok
Module 53 Copy 0........................ : Ok
Module 53 Copy 1........................ : Ok
Module 36 Copy 0........................ : Ok
Module 36 Copy 1........................ : Ok
Module 2F Copy 0........................ : Ok
Module 2F Copy 1........................ : Ok
Module 28 Copy 0........................ : Ok
Module 28 Copy 1........................ : Ok
Module 0C Copy 0........................ : Ok
Module 0C Copy 1........................ : Ok
Module 2A Copy 0........................ : Ok
Module 2A Copy 1........................ : Ok
Module 29 Copy 0........................ : Ok
Module 29 Copy 1........................ : Ok
Module 60 Copy 0........................ : Ok
Module 60 Copy 1........................ : Ok
Module 40 Copy 0........................ : Ok
Module 40 Copy 1........................ : Ok
Module 41 Copy 0........................ : Ok
Module 41 Copy 1........................ : Ok
Module 42 Copy 0........................ : Ok
Module 42 Copy 1........................ : Ok
Module 43 Copy 0........................ : Ok
Module 43 Copy 1........................ : Ok
Module 49 Copy 0........................ : Ok
Module 49 Copy 1........................ : Ok
Module 4A Copy 0........................ : Ok
Module 4A Copy 1........................ : Ok
Module 04 Copy 0........................ : Ok
Module 04 Copy 1........................ : Ok
Module 05 Copy 0........................ : Ok
Module 05 Copy 1........................ : Ok
Module 06 Copy 0........................ : Ok
Module 06 Copy 1........................ : Ok
Module 07 Copy 0........................ : Ok
Module 07 Copy 1........................ : Ok
Module 37 Copy 0........................ : Ok
Module 37 Copy 1........................ : Ok
Module 21 Copy 0........................ : Ok
Module 21 Copy 1........................ : Ok
Module 22 Copy 0........................ : Ok
Module 22 Copy 1........................ : Ok
Module 23 Copy 0........................ : Ok
Module 23 Copy 1........................ : Ok
Module 24 Copy 0........................ : Ok
Module 24 Copy 1........................ : Ok
Module 25 Copy 0........................ : Ok
Module 25 Copy 1........................ : Ok
Module 26 Copy 0........................ : Ok
Module 26 Copy 1........................ : Ok
Module 2D Copy 0........................ : Ok
Module 2D Copy 1........................ : Ok
Module 2E Copy 0........................ : Ok
Module 2E Copy 1........................ : Ok
Module C4 Copy 0........................ : Ok
Module C4 Copy 1........................ : Ok
Module C5 Copy 0........................ : Ok
Module C5 Copy 1........................ : Ok
Module CC Copy 0........................ : Ok
Module CC Copy 1........................ : Ok
Module CA Copy 0........................ : Ok
Module CA Copy 1........................ : Ok
Module CB Copy 0........................ : Ok
Module CB Copy 1........................ : Ok
Module CD Copy 0........................ : Ok
Module CD Copy 1........................ : Ok
Module CF Copy 0........................ : Ok
Module CF Copy 1........................ : Ok
Module CE Copy 0........................ : Ok
Module CE Copy 1........................ : Ok
Module 91 Copy 0........................ : Ok
Module 91 Copy 1........................ : Ok
Module 90 Copy 0........................ : Ok
Module 90 Copy 1........................ : Ok
Module 92 Copy 0........................ : Ok
Module 92 Copy 1........................ : Ok
Module C1 Copy 0........................ : Ok
Module C1 Copy 1........................ : Ok
Module C2 Copy 0........................ : Ok
Module C2 Copy 1........................ : Ok
Module C7 Copy 0........................ : Ok
Module C7 Copy 1........................ : Ok
Module B1 Copy 0........................ : Ok
Module B1 Copy 1........................ : Ok
Module E0 Copy 0........................ : Ok
Module E0 Copy 1........................ : Ok
Module E8 Copy 0........................ : Ok
Module E8 Copy 1........................ : Ok
Module FE Copy 0........................ : Ok
Module FE Copy 1........................ : Ok
Module D5 Copy 0........................ : Ok
Module D5 Copy 1........................ : Ok
Module DA Copy 0........................ : Ok
Module DA Copy 1........................ : Ok
Module DB Copy 0........................ : Ok
Module DB Copy 1........................ : Ok
Module DF Copy 0........................ : Ok
Module DF Copy 1........................ : Ok
Module DD Copy 0........................ : Ok
Module DD Copy 1........................ : Ok
Module D6 Copy 0........................ : Ok
Module D6 Copy 1........................ : Ok
Module D7 Copy 0........................ : Ok
Module D7 Copy 1........................ : Ok
Module D2 Copy 0........................ : Ok
Module D2 Copy 1........................ : Ok
Module BB Copy 0........................ : Ok
Module BB Copy 1........................ : Ok
Module D9 Copy 0........................ : Ok
Module D9 Copy 1........................ : Ok
Module D4 Copy 0........................ : Ok
Module D4 Copy 1........................ : Ok
Module DC Copy 0........................ : Ok
Module DC Copy 1........................ : Ok
Module D0 Copy 0........................ : Ok
Module D0 Copy 1........................ : Ok
Module D3 Copy 0........................ : Ok
Module D3 Copy 1........................ : Ok
Module BA Copy 0........................ : Ok
Module BA Copy 1........................ : Ok
Module B9 Copy 0........................ : Ok
Module B9 Copy 1........................ : Ok
Module BC Copy 0........................ : Ok
Module BC Copy 1........................ : Ok
Module FD Copy 0........................ : Ok
Module FD Copy 1........................ : Ok
Module FB Copy 0........................ : Ok
Module FB Copy 1........................ : Ok
Module E6 Copy 0........................ : Ok
Module E6 Copy 1........................ : Ok
Module E7 Copy 0........................ : Ok
Module E7 Copy 1........................ : Ok
Module BE Copy 0........................ : Ok
Module BE Copy 1........................ : Ok
Module B8 Copy 0........................ : Ok
Module B8 Copy 1........................ : Ok
Module BF Copy 0........................ : Ok
Module BF Copy 1........................ : Ok
Module FC Copy 0........................ : Ok
Module FC Copy 1........................ : Ok
Module EE Copy 0........................ : Ok
Module EE Copy 1........................ : Ok
Module E1 Copy 0........................ : Ok
Module E1 Copy 1........................ : Ok
Module E2 Copy 0........................ : Ok
Module E2 Copy 1........................ : Ok
Module E3 Copy 0........................ : Ok
Module E3 Copy 1........................ : Ok
Module E4 Copy 0........................ : Ok
Module E4 Copy 1........................ : Ok
Module E5 Copy 0........................ : Ok
Module E5 Copy 1........................ : Ok
Module E9 Copy 0........................ : Ok
Module E9 Copy 1........................ : Ok
Module DE Copy 0........................ : Ok
Module DE Copy 1........................ : Ok
Module FA Copy 0........................ : Ok
Module FA Copy 1........................ : Ok
SA surface verification
There is no description of SA in the zone allocation table
So i tried this i get a donnor, and write P list on Donnor the Regen translator the HSwap, after this, the HDD was detected, and when i tried again the all heads , not show any problem, but if i tried to access sector show AMNF even i can did the head test, showing all OK, now after did the H swap, i can get the SA tracks, so im thinking on write modules and tracks, what do u suggest me thanks friend
Sinceraly
Alberto
 Post subject: Re: WD 800BB
PostPosted: January 10th, 2008, 18:53
Hello friend´s
I made mistake, by this reason show me AMNF, this was my mistake, i wrote P LIST on Donnor, but on Marvell its not the Same ID; like, Cil 16 or Cil 32, So after wrote the correct module concerned P list on Marvell, and did the translator regeneration process, the HDD was detected, and i can access sectors by sector, edit, i can get the MBR, Partition table, Sector 63 Boot sector , etc so itried DE, and was sucess, show me the complete partition, and directories, but when i tried to save "x" file, while was progressing the progress bar, at some times begin´s to show UNC, so i stop, and now tried the Clone to another HDD now its on this process, but with some errors, not continuisly error´s but at some times show errors and jump this bad zone on the task . What do u think , could be a bad head, or my another theory on my mistake i wrote the 43h module thinking on the P LIST but on marvell its not its adaptive data, do u think this could be the reason.
Best Regards
Alberto
