 Post subject: Maxtor Proxima 34098H4 Firmware Help
PostPosted: January 14th, 2008, 14:10
SA structure test
Selected family ........................... Proxima
Model ..................................... Maxtor 34098H4
Firmware .................................. YAH814Y0
Serial .................................... L408J8KC
Min. cylinder ............................. 375
Max. cylinder ............................. 34832
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... NO_ULIST
Checksum .................................. Error
The number of SA defects .................. 2
P-List size ............................... 5
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Serial number ............................. L408J8KC
Max LBA ................................... 80043264
Head number ............................... 4
Head map .................................. 2 3 4 5
SA head map ............................... 2 3 4 5
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV6öJ
Checksum .................................. Ok
Checking User data adaptives
Header .................................... CRFTÆ
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 375: 3020: 720
2 : 3021: 5527: 704
3 : 5528: 7523: 693
4 : 7524: 9242: 680
5 : 9243: 11375: 662
6 : 11376: 15103: 640
7 : 15104: 17505: 608
8 : 17506: 19767: 586
9 : 19768: 22206: 560
10 : 22207: 23379: 544
11 : 23380: 25570: 520
12 : 25571: 26882: 502
13 : 26883: 29332: 480
14 : 29333: 31197: 448
15 : 31198: 32833: 426
16 : 32834: 34832: 400
17 : 34833: 34880: 320
Checking ROM Copy
Check sum Value ........................... 1BAA
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 4B00
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
Checking Techno mode overlays
Header2 ................................... 4BY.
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
Checking RZTbl
Checking P-List
Size ...................................... Unknown
Checking G-List
Checking RZTbl-PList
Sect.Count Rec.Offset Rec Length Beg.Cyl. End Cyl.
0 74 16 2195 2558
10 92 12 2559 2922
0 106 2 2923 3020
1 110 4 3021 3392
1 116 4 3393 3764
0 122 2 3765 4136
6 126 10 4137 4508
1 138 4 4509 4880
0 144 2 4881 5252
0 148 2 5253 5527
0 152 2 5528 5905
1 156 4 5906 6283
3 162 6 6284 6661
2 170 6 6662 7039
2 178 6 7040 7417
5 186 8 7418 7523
0 196 2 7524 7908
2 200 4 7909 8293
0 206 2 8294 8678
1 210 4 8679 9063
0 216 2 9064 9242
0 220 2 9243 9637
3 224 6 9638 10032
1 232 4 10033 10427
0 238 2 10428 10822
4 242 8 10823 11217
0 252 2 11218 11375
8 256 10 11376 11784
0 268 2 11785 12193
3 272 8 12194 12602
0 282 2 12603 13011
0 286 2 13012 13420
0 290 2 13421 13829
0 294 2 13830 14238
0 298 2 14239 14647
0 302 2 14648 15056
0 306 2 15057 15103
3 310 8 15104 15534
0 320 2 15535 15965
0 324 2 15966 16396
2 328 6 16397 16827
0 336 2 16828 17258
0 340 2 17259 17505
2 344 6 17506 17952
4 352 8 17953 18399
0 362 2 18400 18846
4 366 8 18847 19293
0 376 2 19294 19740
0 380 2 19741 19767
3 384 8 19768 20235
2 394 6 20236 20703
0 402 2 20704 21171
1 406 4 21172 21639
0 412 2 21640 22107
0 416 2 22108 22206
128 420 6 22207 22687
1 428 4 22688 23168
0 434 2 23169 23379
0 438 2 23380 23883
0 442 2 23884 24387
0 446 2 24388 24891
0 450 2 24892 25395
0 454 2 25396 25570
0 458 2 25571 26092
1 462 6 26093 26614
0 470 2 26615 26882
3 474 8 26883 27428
0 484 4 27429 27974
2 490 4 27975 28520
0 496 2 28521 29066
2 500 6 29067 29332
Checking RZTbl-HList
Difference ................................ not found
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 241
Checking security
Header .................................... SECU
User Password ............................. " "
Master Password ........................... "Maxtor "
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking [DISK/PW]
not found
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 ................................. Ok
Module 19 ................................. Ok
Module 1A ................................. Ok
Module 1B ................................. Ok
Module 1C ................................. Ok
Module 1D ................................. Ok
Module 1E ................................. Ok
Module 1F ................................. UBA 0 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 34833/2/0
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. Ok
Module 24 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. Ok
Module 30 ................................. Ok
Module 31 ................................. Ok
Module 32 ................................. Ok
Module 33 ................................. Ok
Module 34 ................................. Ok
Module 35 ................................. Ok
Module 37 ................................. Ok
Module 38 ................................. Ok
Module 39 ................................. Ok
Module 41 ................................. Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 ................................. Ok
Module 45 ................................. Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E ................................. Ok
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. Ok
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. Ok
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 6C ................................. Ok
Module 6D ................................. Ok
Module 6E ................................. Ok
Module 6F ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 ................................. Ok
Module 79 ................................. Ok
Module 7B ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
 Post subject: Re: Maxtor Proxima 34098H4 Firmware Help
PostPosted: January 15th, 2008, 17:38
And? What you need form the drive?
DataRecovery.bg
PostPosted: January 16th, 2008, 16:47
I need to recover Users data Module 1F comes out bad and when I try to clone the drive the drive just has errors, do I need a good module 1F or should the drive work without this? Thank you
PostPosted: January 18th, 2008, 3:59
Well, since you have PCI you must have and manual for it.
The importance of 1F module is described there, also and compatibility with modules taken from database.
Pay attention to
and
DataRecovery.bg
PostPosted: February 5th, 2008, 9:35
AFTER REPLACING MODULE 1F DRIVE STILL UNREADABLE PLEASE HELP...
SA structure test
Serial .................................... L424NT6C
Checking UList
Header .................................... U_LIST00
Serial number ............................. L424NT6C
Checking Zone Table
1 : 375: 3020: 720
2 : 3021: 5527: 704
3 : 5528: 7523: 693
4 : 7524: 9242: 680
Checking ROM Copy
Checking RZTbl
Checking P-List
Checking G-List
0 74 16 2195 2558
10 92 12 2559 2922
0 106 2 2923 3020
1 110 4 3021 3392
1 116 4 3393 3764
0 122 2 3765 4136
6 126 10 4137 4508
1 138 4 4509 4880
0 144 2 4881 5252
0 148 2 5253 5527
0 152 2 5528 5905
1 156 4 5906 6283
3 162 6 6284 6661
2 170 6 6662 7039
2 178 6 7040 7417
5 186 8 7418 7523
0 196 2 7524 7908
2 200 4 7909 8293
0 206 2 8294 8678
1 210 4 8679 9063
0 216 2 9064 9242
0 220 2 9243 9637
3 224 6 9638 10032
1 232 4 10033 10427
0 238 2 10428 10822
4 242 8 10823 11217
0 252 2 11218 11375
0 268 2 11785 12193
3 272 8 12194 12602
0 282 2 12603 13011
0 286 2 13012 13420
0 290 2 13421 13829
0 294 2 13830 14238
0 298 2 14239 14647
0 302 2 14648 15056
0 306 2 15057 15103
3 310 8 15104 15534
0 320 2 15535 15965
0 324 2 15966 16396
2 328 6 16397 16827
0 336 2 16828 17258
0 340 2 17259 17505
2 344 6 17506 17952
4 352 8 17953 18399
0 362 2 18400 18846
4 366 8 18847 19293
0 376 2 19294 19740
0 380 2 19741 19767
3 384 8 19768 20235
2 394 6 20236 20703
0 402 2 20704 21171
1 406 4 21172 21639
0 412 2 21640 22107
0 416 2 22108 22206
1 428 4 22688 23168
0 434 2 23169 23379
0 438 2 23380 23883
0 442 2 23884 24387
0 446 2 24388 24891
0 450 2 24892 25395
0 454 2 25396 25570
0 458 2 25571 26092
1 462 6 26093 26614
0 470 2 26615 26882
3 474 8 26883 27428
0 484 4 27429 27974
2 490 4 27975 28520
0 496 2 28521 29066
2 500 6 29067 29332
Checking HLists
Block0
Checking security
Checking S.M.A.R.T.
Checking [DISK/PW]
not found
Checking All
Module 1F ................................. Ok
PostPosted: February 13th, 2008, 10:11
Is there anyone who can help with this problem please??
PostPosted: February 17th, 2008, 9:28
do u need the data or just repair drive ?
PostPosted: February 17th, 2008, 19:15
Need data for customer.
PostPosted: February 18th, 2008, 14:58
I think U should be able to find the problem with this drive looking at the log...
:wink:
PostPosted: February 20th, 2008, 10:22
pepe,
I see that the problem is the checksum error I need help correcting this to recover user data> I am new to the machine and was looking for help w a quick answer if you could PM me. Thank you.
PostPosted: February 20th, 2008, 18:45
my main problem is that if U have original/legal utils, U should also have some manuals/support from the manufacturer...
PostPosted: February 21st, 2008, 16:35
pepe,
Yes I have it and was just looking for a quick answer and help with the problem. So can you provide help or are you just fishing for other stuff??
PostPosted: February 26th, 2008, 15:41
just rewrite 1F module .
Users browsing this forum: No registered users and 31 guests
