 Post subject: Fujitsu cant ID
PostPosted: January 17th, 2008, 21:17
Hi Forum
I have recieved a new drive direct from suppliers which appears to be DOA.
packaging all looks fine with no visible signs of being dropped or mishandled, antistatic bag still sealed correctly.
Bios wont detect so attached on to PC3000 and recieved below results,
just wondering if in your opinions it is firmware issues or possiblly heads, there is no sign of noises besides normal spinning noises.
Drive will go back to supplier for warranty claim but before going back just wanted to see what the issues may be.
thx in advance.
Selected family......................... : MHV2xxxAT
Selected model.......................... : MHV2080AH
Model by HDD ID......................... : <HDD ID NOT READ>
ROMInfo reading......................... : Error
Error reading ROM
Initializing "default" ROM parameters
Module table (ROM)...................... : Initializing with default parameters
Loading : HS, head map module......................................... : Error
Error................................................................. : Drive not ready
Loading : PL, single sector defect list and zone allocation table modu : Error
Test : SA structure test
LOADING MODULES
Drive not ready
Module 0101........................................................... : Error
Drive not ready
Module 0102........................................................... : Error
Drive not ready
Module 0103........................................................... : Error
Drive not ready
Module 0104........................................................... : Error
Drive not ready
Module 0105........................................................... : Error
Drive not ready
Module 0106........................................................... : Error
Drive not ready
Module 0107........................................................... : Error
Drive not ready
Module 0108........................................................... : Error
Drive not ready
Module 0109........................................................... : Error
Drive not ready
Module 010A........................................................... : Error
Drive not ready
Module 010B........................................................... : Error
Module 010C........................................................... : Ok
Module 010D........................................................... : Ok
Module 010E........................................................... : Ok
Module 0110........................................................... : Ok
Module 0111........................................................... : Ok
Module 0112........................................................... : Ok
Module 0113........................................................... : Ok
Module 0114........................................................... : Ok
Module 0115........................................................... : Ok
Module 0116........................................................... : Ok
Module 0117........................................................... : Ok
Module 0118........................................................... : Ok
Module 0119........................................................... : Ok
Module 011C........................................................... : Ok
Module 011D........................................................... : Ok
Module 011E........................................................... : Ok
Module 011F........................................................... : Ok
Module 0120........................................................... : Ok
Module 0121........................................................... : Ok
Module 0122........................................................... : Ok
Can`t read module 0127 from HDD
Module 0127........................................................... : Error
Module 0128........................................................... : Ok
Module 0129........................................................... : Ok
Module 012A........................................................... : Ok
Can`t read module 012B from HDD
Module 012B........................................................... : Error
Can`t read module 012D from HDD
Module 012D........................................................... : Error
Module 012E........................................................... : Ok
Module 0130........................................................... : Ok
Can`t read module 0131 from HDD
Module 0131........................................................... : Error
Module 0132........................................................... : Ok
Module 0135........................................................... : Ok
Module 0136........................................................... : Ok
Can`t read module 0137 from HDD
Module 0137........................................................... : Error
Module 013D........................................................... : Ok
Module 013E........................................................... : Ok
Module 013F........................................................... : Ok
Module 0140........................................................... : Ok
Module 0141........................................................... : Ok
Module 0142........................................................... : Ok
Module 0145........................................................... : Ok
Can`t read module 0150 from HDD
Module 0150........................................................... : Error
Can`t read module 0151 from HDD
Module 0151........................................................... : Error
Can`t read module 0152 from HDD
Module 0152........................................................... : Error
Can`t read module 0154 from HDD
Module 0154........................................................... : Error
Module 0155........................................................... : Ok
Module 0156........................................................... : Ok
Module 015A........................................................... : Ok
Module 015B........................................................... : Ok
Module 0160........................................................... : Ok
Module 0161........................................................... : Ok
Module 0162........................................................... : Ok
Module 0163........................................................... : Ok
Module 0164........................................................... : Ok
Module 0165........................................................... : Ok
Module 0170........................................................... : Ok
Module 0180........................................................... : Ok
Module 0181........................................................... : Ok
Module 0182........................................................... : Ok
Module 0183........................................................... : Ok
Module 0184........................................................... : Ok
Module 0185........................................................... : Ok
Module 0186........................................................... : Ok
Module 0187........................................................... : Ok
Module 0188........................................................... : Ok
Module 0189........................................................... : Ok
Module 018A........................................................... : Ok
Module 018B........................................................... : Ok
Module 018C........................................................... : Ok
Module 018D........................................................... : Ok
Module 018E........................................................... : Ok
Module 018F........................................................... : Ok
Module 0190........................................................... : Ok
Module 0191........................................................... : Ok
Module 0192........................................................... : Ok
Module 0193........................................................... : Ok
Module 0194........................................................... : Ok
Module 0195........................................................... : Ok
Module 0196........................................................... : Ok
Module 0197........................................................... : Ok
Module 0198........................................................... : Ok
Module 0199........................................................... : Ok
Module 019A........................................................... : Ok
Module 019B........................................................... : Ok
Module 019C........................................................... : Ok
Module 019D........................................................... : Ok
Module 019E........................................................... : Ok
Module 019F........................................................... : Ok
Module 01A1........................................................... : Ok
Module 01A2........................................................... : Ok
Module 01B0........................................................... : Ok
Module 01B1........................................................... : Ok
Module 01B2........................................................... : Ok
Module 01B3........................................................... : Ok
Module 01B4........................................................... : Ok
Module 01C0........................................................... : Ok
Can`t read module 01E0 from HDD
Module 01E0........................................................... : Error
Module 01E1........................................................... : Ok
Module 01E2........................................................... : Ok
Module 01E3........................................................... : Ok
Module 01E4........................................................... : Ok
Module 01E5........................................................... : Ok
Module 01E6........................................................... : Ok
Module 01E7........................................................... : Ok
Module 01E8........................................................... : Ok
Module 01E9........................................................... : Ok
Module 01EA........................................................... : Ok
Module 0201........................................................... : Ok
Module 0204........................................................... : Ok
Module 0206........................................................... : Ok
Module 0207........................................................... : Ok
Module 0208........................................................... : Ok
Module 020C........................................................... : Ok
Module 020D........................................................... : Ok
Module 0220........................................................... : Ok
Module 0222........................................................... : Ok
Module 0227........................................................... : Ok
Can`t read module 022B from HDD
Module 022B........................................................... : Error
Module 0237........................................................... : Ok
Module 0241........................................................... : Ok
Module 0242........................................................... : Ok
Module 0255........................................................... : Ok
Module 0256........................................................... : Ok
Module 02B0........................................................... : Ok
Module 02B1........................................................... : Ok
Module 02B2........................................................... : Ok
Module 02B3........................................................... : Ok
Module 02B4........................................................... : Ok
Module 02E0........................................................... : Ok
Module 02E1........................................................... : Ok
Module 02E2........................................................... : Ok
Module 02E5........................................................... : Ok
Module 02E6........................................................... : Ok
Module 02E7........................................................... : Ok
Module 02E8........................................................... : Ok
Module 02EA........................................................... : Ok
Users browsing this forum: No registered users and 46 guests
