 Post subject: What to match for WD PCB replacement?
PostPosted: January 23rd, 2008, 17:39
Hi all,
I am just wondering which numbers must definitely match to swap a PCB on a WD2500JB drive.
The model no is WD2500JB-55GVC0, the PCB ID is 2061-701265-200. I am prepared to swap the serial flash ROM to the donor PCB and would do so with other components if necessary.
But first I need to identify a suitable donor. Anyone?
regards
 Post subject: Re: What to match for WD PCB replacement?
PostPosted: January 24th, 2008, 2:38
Hi, You only need to match 2061-701265, and swap the rom.
Regards/ Bosse
http://www.rescue-it.se
PostPosted: January 24th, 2008, 4:35
Thanks Bosse,
so I'll look for a compatible PCB.
regards
