January 25th, 2008, 9:28
Hi to all!
Hdd already arrived pra me damaged with previous attempts to remove platter, will not use correct tool damaging the screw.
I have that to remove platter as I make to create a traction in the screw to loosen it?
Look photo!
- Attachments
- damaged screw.JPG (4.96 KiB) Viewed 4185 times
January 25th, 2008, 12:02
You can get screw extractors at a a hardware store. They look like tapered screws with reverse threads. You may have to drill a hole into the screw. Also, there is new product on the market called ScrewGrab thay may help. (
http://main.screwgrab.com)
January 28th, 2008, 7:13
Thanks for help!
January 29th, 2008, 16:33
decided problem!
