 Post subject: Seagate Barracude 7200.10 burnt motor cont. chip
PostPosted: February 4th, 2008, 0:46
I have a burnt motor controller chip on Seagate Barracude 7200.10, 500Gbytes
Replaced the SMOOTH and blew up again.
Is it sufficient to get the drive working by swapping the ROM with the same model to donor drive? or model and firmware must be the same?
Thank you
 Post subject: Re: Seagate Barracude 7200.10 burnt motor cont. chip
PostPosted: February 4th, 2008, 1:56
The ROM on the board does not contain adaptives, so it will not help you to swap it.
You need to find a PCB with a similar MPU, as the ROM information is embedded in the processor.
Jon
http://www.datasaversllc.com
PostPosted: February 4th, 2008, 6:00
hi Jono, "You need to find a PCB with a similar MPU", you mean same model and firmware?
PostPosted: February 4th, 2008, 6:50
MPU is the Main Processor Unit....aka cpu
www.datasave.ro
PostPosted: February 4th, 2008, 10:59
That's a good place to start, but no guarantee. I just tried a board swap on a Seagate with the same model and firmware. However, the site codes were different (same country!) and the actual FW was different enough that the boards would not match!
Users browsing this forum: Majestic-12 [Bot] and 123 guests
