 Post subject: Maxtor 80GB YAR41BW0 Recovery
PostPosted: February 1st, 2008, 18:12
I have a Maxtor 80GB YAR41BW0 which IC motor has shorted.
After much sourcing i have got a identical board to replace it with but do not have an identical firmware for the board.
Could i de-solder the fw chip from one onto the other? Or is there a software solution to this?
I would love to get my photoshop work back.
Cheers guys for any help you can give!
 Post subject: Re: Maxtor 80GB YAR41BW0 Recovery
PostPosted: February 1st, 2008, 22:17
Hi!
You probably have some other issues with a drive.
www.datarecoveryne.com
PostPosted: February 2nd, 2008, 8:57
i have done a proper check and all that appears to be at fault is the ic, the new board does not burn out when installed. Drive spins up but is not recognised properly as the firmware is either not present or incorrect.
PostPosted: February 2nd, 2008, 17:06
What do you have showing for a firmware version?
PostPosted: February 3rd, 2008, 0:51
Garbled data, i actually beleive the firmware on the drives firmware was wiped. The PCB's are identical down to everything else though.
PostPosted: February 3rd, 2008, 2:16
Please provide a firmware version that you have.
We might be able to tell you what is a problem with your drive.
PostPosted: February 3rd, 2008, 8:20
Does the original PCB have a ROM?
If it does not then, any matching PCB should work.
If it does, then you need to transfer the ROM over.
If you don't know, then post a pic of thr PCB.
PostPosted: February 3rd, 2008, 14:06
These drives usually have 8 pin ROMs, but I don't think the ROMs contain adaptive info. The important factors for a match are the white sticker near the power connector, and the CPU.
For example, yesterday I was able to use a D6FYA board from a 60 GB Maxtor to replace a D8FYA PCB by just changing the ROM. The "upgraded" PCB was able to perfectly image two drives from a RAID.
Jon
http://www.datasaversllc.com
PostPosted: February 3rd, 2008, 20:56
http://img98.imageshack.us/img98/3070/oldyv7.jpg this is the old board where the IC controller has burnt out (i have read this is a common fault with this drive).
http://img98.imageshack.us/img98/3711/newls6.jpg This is the new board, there is no sticker under the ide connector for this one but both ic chips are matching numbers and boards are for the same drive.
where is the rom chip located?
I'm lucky to be doing techical computing at university so i have most things availible for me if i need to try a rom swap.
Or would it be possible to flash the rom via a jtag type device?
Thanks guys for all your reply's.
PostPosted: February 4th, 2008, 1:54
The ROM is 25P10V - maybe Q400 on your PCB.
PostPosted: February 4th, 2008, 4:05
On this pcb rom is masked in main chip so no need for change,it should be q401 but its missing.Just put on your replacement pcb and it should work if preamp isnt burned!
PostPosted: February 4th, 2008, 14:42
Yep, your drive has no external ROM.
The replacement PCB should work OK, assuming HDA is OK.
Users browsing this forum: shubhsinghal and 74 guests
