 Post subject: The "fall" of my HDD.
PostPosted: October 26th, 2007, 15:13
Greetings.
Today was a realy bad day for me.Part of the bad things happened is the fall of my Maxtor (Maxtor DiamondMax 10 300GB PATA133 [Model:6L300R0])(External Drive).The HDD fall from my bed down to floor.The result was my HDD to stop being recognised by WIN (Win XP Home SP2) and also when i plug him he make a strange noise (beeper + scratching).
Any clue what can i do now
1st To save my Data (about 240GB total 120-130Needed)
2nd To save my HDD and continue its use.
I asked in some local PC stores and they sayed that they are be able to check the disc and maybe change the headers.Is this possible and if yes am i going to face problems in future use of my HDD?
Thanks in advance.
 Post subject: Re: The "fall" of my HDD.
PostPosted: October 26th, 2007, 15:48
Hi Wos,
1- Is it possible to save your data: Perhaps; it depends on how bad the heads will have touched the platters. This is a job for a professional data-recovery company
2- can you use the drive thereafter: No, impossible. This drive is for the garbage.
Best regards,
Dobre
Murphy was an optimist
PostPosted: October 27th, 2007, 18:31
When these Maxtors take a fall, often the bearings lock up and it's extremely difficult to turn the motor.
This is a job for a pro shop if you want your data back.
http://www.datasaversllc.com
PostPosted: February 9th, 2008, 2:11
If it sings ( almost like it plays music), the platters are definitely stuck, I have about 10 of these drives that were dropped in portable enclosures, all have spindle seizure.
I think ST is a sub company of Lucas
Users browsing this forum: Austinblake22 and 68 guests
