 Post subject: Seagate Barracuda with MASKROM - 1_Disk
PostPosted: February 27th, 2008, 13:14
Seagate 7200.7. This is an unusual one which I havent seen before.
Terminal comes up with:
Interface task reset
1024k x 16 buffer detected
MASKROM - 1_Disk M-20 12-07-03 15:39
F>
It fails to identify the Family - instead is shows "MASKROM"
"." returns:
F>Pgm=00 Trk=00000000(00000000).0(0).000(000) Zn=2E Err=29 ErCt=0000 Hlth=0000 CHlth=0000 Ntrdy LBA=00000000
I do not have a PCB match, so havent yet tried a PCB exchange. Could this be a firmware/flash rom issue which can be solved using the current PCB and correct firmware, or is the PCB probably damaged which would require me to find a suitable donor?
Any suggestions?
JJ
 Post subject: Re: Seagate Barracuda with MASKROM - 1_Disk
PostPosted: February 27th, 2008, 16:56
Hi
Probably the rom contents has been damaged, needs to be reprogrammed...
PostPosted: February 27th, 2008, 20:02
hi
pepe u r really professional
PostPosted: February 28th, 2008, 2:30
PostPosted: March 6th, 2008, 15:09
If the ROM is masked in the CPU like in most 7200.7 drives could it be reprogrammed ?
PostPosted: March 18th, 2008, 4:12
HI,Please call me !!! I can help you!!!
My-EM:wuxinwei110@163.com
PostPosted: March 18th, 2008, 10:11
No, if PCB doesn't have a flash chip. You cannot reprogram maskrom through serial port, only flash chip
If flash chip is absent you need to solder flash chip and SMD capasitor on PCB to make it work
If flash chip is on the place - try to reprogram it, if you can't - chip is dead and you need to replace it with a good one
PostPosted: March 18th, 2008, 12:15
Doomer:
I am confused.
If you have a drive without a flash IC, then the code is in the CPU (masked). Correct?
If you then add a flash IC and capacitor, will the CPU give priority to the code in the external flash ROM vs. it's own (internal) masked ROM?
Thank you.
Jon
http://www.datasaversllc.com
PostPosted: March 18th, 2008, 14:47
That's correct
PostPosted: March 18th, 2008, 19:37
That's correct
Spacebo, Tovarish!
PostPosted: March 18th, 2008, 21:52
jono-ats wrote:
Spacebo, Tovarish!
you are welcome :)
PostPosted: March 19th, 2008, 15:43
So that means if there is ROM curruption in the masked ROM then i can add a capacitor and a programmed rom i can overcome this problem ?
PostPosted: March 19th, 2008, 17:15
yes
but mask-ROM hardly could be damaged
Users browsing this forum: Majestic-12 [Bot] and 66 guests
