 Post subject: Why are Seagate drives so inscrutable?
PostPosted: March 6th, 2008, 23:46
I have a Seagate 320 GB ATA drive that came ready briefly. I could image a few hundred sectors from the beginning or the end with DE, but then the drive would go into busy mode and not come out. Here is the log message. It appears like a head is failing; otherwise, I don't have a clue. Can anyone help and point out subsequent troubleshooting steps?
Age=50 Type=18 MxCyl=227B9 MxHd=3 MxSct=434 BSz=016M TCode=0102FC00 ThermFlts=0000
(S)PATA Reset
a212
CE Log ErrCode=0 LBA=c28a44 Type=8Master
AT Er 00 Nwt Er 43 RdWr 008ed.03.03fd
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 0008ed.03.03fd
CE Log ErrCode=43 LBA=c28a46 Type=5 Add To Pending c28a46
AT Er 00 Nwt Er 43 RdWr 008ed.03.0402
Niwot: 9ff79ff7 b6 9ff79ff7.3.640 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 0008ed.03.0402
CE Log ErrCode=43 LBA=c28a4b Type=5 Add To Pending c28a4b
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.03fe
Niwot: 00c28a47 14 00c28a47.2.590 0004 3642 0004 0000
Spare of 00c28a47 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.03ff
Niwot: 00c28a48 14 00c28a48.2.590 0003 3643 0003 0000
Spare of 00c28a48 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0400
Niwot: 00c28a49 14 00c28a49.2.590 0002 3644 0002 0000
Spare of 00c28a49 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0401
Niwot: 00c28a4a 14 00c28a4a.2.590 0001 3645 0001 0000
Spare of 00c28a4a failed
AT Er 00 Nwt Er 43 RdWr 008ed.03.040f
DiskAccess ReadSector EC=43 at 0008ed.03.040f
CE Log ErrCode=43 LBA=c28a58 Type=5 Add To Pending c28a58
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0403
Niwot: 00c28a4c 14 00c28a4c.2.590 000c 3642 000c 0000
Spare of 00c28a4c failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0404
Niwot: 00c28a4d 14 00c28a4d.2.590 000b 3643 000b 0000
Spare of 00c28a4d failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0405
Niwot: 00c28a4e 14 00c28a4e.2.590 000a 3644 000a 0000
Spare of 00c28a4e failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0406
Niwot: 00c28a4f 14 00c28a4f.2.590 0009 3645 0009 0000
Spare of 00c28a4f failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0407
Niwot: 00c28a50 14 00c28a50.2.590 0008 3646 0008 0000
Spare of 00c28a50 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0408
Niwot: 00c28a51 14 00c28a51.2.590 0007 3647 0007 0000
Spare of 00c28a51 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0409
Niwot: 00c28a52 14 00c28a52.2.590 0006 3648 0006 0000
Spare of 00c28a52 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.040a
Niwot: 00c28a53 14 00c28a53.2.590 0005 3649 0005 0000
Spare of 00c28a53 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.040b
Niwot: 00c28a54 14 00c28a54.2.590 0004 364a 0004 0000
Spare of 00c28a54 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.040c
Niwot: 00c28a55 14 00c28a55.2.590 0003 364b 0003 0000
Spare of 00c28a55 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.040d
Niwot: 00c28a56 14 00c28a56.2.590 0002 364c 0002 0000
Spare of 00c28a56 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.040e
Niwot: 00c28a57 14 00c28a57.2.590 0001 364d 0001 0000
Spare of 00c28a57 failed
AT Er 00 Nwt Er 43 RdWr 008ed.03.0415
DiskAccess ReadSector EC=43 at 0008ed.03.0415
CE Log ErrCode=43 LBA=c28a5e Type=5 Add To Pending c28a5e
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0410
Niwot: 00c28a59 14 00c28a59.2.590 0005 3642 0005 0000
Spare of 00c28a59 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0411
Niwot: 00c28a5a 14 00c28a5a.2.590 0004 3643 0004 0000
Spare of 00c28a5a failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 008ed.03.0412
Niwot: 00c28a5b 14 00c28a5b.2.590 0003 3644 0003 0000
Spare of 00c28a5b failed
Thanks,
Jon
http://www.datasaversllc.com
 Post subject: Re: Why are Seagate drives so inscrutable?
PostPosted: March 6th, 2008, 23:55
Hello jon
Typical problem on seagate je, this case reach´s DRDY DSC; the best its like u are doing trying to clone im know it ´s very slow u can did head map and tried to "play" with settings like soft, hard reset, recalibration, when u checked its loosening readiness, tried to did soft reset by hand , another tip if its making many noise, opend i and tried to play with the MHA Axis, but be carefull i had some cased like u and image it , after that check u pm :wink:
Best regards
PostPosted: March 7th, 2008, 0:13
EC=43 - UNC error. Head3 has problems...
Try to image around it first.
PostPosted: March 7th, 2008, 16:23
I also had this problem but in the last 10G of the LBA space.
I could run verifying from the beginning till the bad area with full speed, but when i tried reading, the messages would come and reading was extremely slow.
Head test revealed no problems.
I mapped out the area in the zone table, and the messages stopped. I could clone the drive till the bad area.
When I changed back the zone table, the messages didn't come back, but the last 10G was still unreadable.
there wasn't any problem with the heads...
PostPosted: March 7th, 2008, 17:56
I appreciate all of your replies.
It took a long time to make a head map. I turned off heads selectively, and tried soft & hard reset, UDMA33 vs. hardware retries, etc.
I couldn't image more than a few hundred sectors before the drive went busy and errored out.
I think I'm stuck . . . .
PostPosted: March 7th, 2008, 19:17
can u run verifying?
what if u run from let's say LBA=10.000.000?
PostPosted: March 7th, 2008, 23:30
Pepe,
Same result regardless of head or starting position!
PostPosted: March 8th, 2008, 6:28
I got a very similar problem with a 7200.9 250Gb.
Interface task reset
4096k x 16 SDRAM
TONKA15 - 1_Disk S.59 12-09-05 11:07
Spin Ready
(P)PATA Reset
Master
AT Er 00 Nwt Er 43 RdWr 0014d.00.0272
Niwot: 97f29ff7 b6 97f29ff7.1.725 0000 005f 0000 0002
CE Log ErrCode=43 LBA=1677df Type=4 Remove from Pending 1677df
AT Er 00 Nwt Er 43 RdWr 0014d.00.0280
Niwot: 9ff79ff7 b6 9ff79ff7.1.725 0000 005f 0000 0002
DiskAccess ReadSector EC=43 at 00014d.00.0280
CE Log ErrCode=43 LBA=1677ed Type=5 Add To Pending 1677ed
CE Log ErrCode=43 LBA=16756d Type=6aAT Er 00 Nwt Er 43 RdWr 0014e.00.0184
Niwot: 97f29ff7 b6 97f29ff7.1.725 0000 005f 0000 006a
DiskAccess ReadSector EC=43 at 00014e.00.0184
CE Log ErrCode=43 LBA=167bda Type=5 Add To Pending 167bda
AT Er 00 Nwt Er 43 RdWr 0014e.00.019b
Niwot: 9ff79ff7 b6 9ff79ff7.1.725 0000 005f 0000 006a
DiskAccess ReadSector EC=43 at 00014e.00.019b
CE Log ErrCode=43 LBA=167bf1 Type=5 Add To Pending 167bf1
AT Er 00 Nwt Er 43 RdWr 0014e.00.01a7
DiskAccess ReadSector EC=43 at 00014e.00.01a7
CE Log ErrCode=43 LBA=167bfd Type=5 Add To Pending 167bfd
AT Er 00 Nwt Er 43 RdWr 0014e.00.01b2
DiskAccess ReadSector EC=43 at 00014e.00.01b2
CE Log ErrCode=43 LBA=167c08 Type=5 Add To Pending 167c08
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 0014e.00.01b1
Niwot: 00167bfe 14 00167bfe.0.000 000a 1727 000a 0000
Spare of 00167c07 failed
AT Er 00 Nwt Er 43 RdWr 0014e.00.01b8
DiskAccess ReadSector EC=43 at 00014e.00.01b8
CE Log ErrCode=43 LBA=167c0e Type=5 Add To Pending 167c0e
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 0014e.00.01b3
Niwot: 00167c09 14 00167c09.0.000 0005 1727 0005 0000
Spare of 00167c09 failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 0014e.00.01b4
Niwot: 00167c0a 14 00167c0a.0.000 0004 1728 0004 0000
Spare of 00167c0a failed
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 0014e.00.01b7
Niwot: 00167c0b 14 00167c0b.0.000 0003 1729 0003 0000
Spare of 00167c0d failed
AT Er 00 Nwt Er 43 RdWr 0014e.00.01b9
DiskAccess ReadSector EC=43 at 00014e.00.01b9
CE Log ErrCode=43 LBA=167c0f Type=5 Add To Pending 167c0f
AT Er 00 Nwt Er 43 RdWr 0014e.00.01bd
DiskAccess ReadSector EC=43 at 00014e.00.01bd
CE Log ErrCode=43 LBA=167c13 Type=5 Add To Pending 167c13
CorrectWriteStart
AT Er 00 Nwt Er 13 RdWr 0014e.00.01ba
Niwot: 00167c10 14 00167c10.0.000 0003 1727 0003 0000
Spare of 00167c10 failed
But it will logical verify OK, if a little slow in some places.
PostPosted: March 8th, 2008, 7:40
When I am verifying LBA's, this comes up in terminal...
P)(H)PATA Reset
Master
(S)PATA Reset
d8Master
(S)PATA Reset
e3Master
(S)PATA Reset
e0Master
(S)PATA Reset
e4Master
(S)PATA Reset
d6Master
(S)PATA Reset
eeMaster
(S)PATA Reset
dcMaster
(S)PATA Reset
e2Master
(S)PATA Reset
d9Master
(S)PATA Reset
e1Master
(S)PATA Reset
eaMaster
(S)PATA Reset
e3Master
(S)PATA Reset
e1Master
(S)PATA Reset
e1Master
(S)PATA Reset
e3Master
(S)PATA Reset
d8Master
(S)PATA Reset
d6Master
(S)PATA Reset
dcMaster
(S)PATA Reset
e0Master
(S)PATA Reset
dbMaster
(S)PATA Reset
e8Master
(S)PATA Reset
dcMaster
(S)PATA Reset
e6Master
(S)PATA Reset
ebMaster
(S)PATA Reset
dfMaster
(S)PATA Reset
d8Master
(S)PATA Reset
e3Master
(S)PATA Reset
efMaster
(S)PATA Reset
e2Master
(S)PATA Reset
e4Master
(S)PATA Reset
d4Master
(S)PATA Reset
e5Master
(S)PATA Reset
dbMaster
(S)PATA Reset
e5Master
(S)PATA Reset
Master
(S)PATA Reset
e5Master
(S)PATA Reset
d3Master
(S)PATA Reset
e5Master
(S)PATA Reset
e2Master
(S)PATA Reset
e1Master
Any ideas?
PostPosted: March 11th, 2008, 21:51
Starling - I'm assuming you mean to deselect HEAD 3 in the head map(Task Info) and then copy? What do you do after that to reconstruct the logical structure?
A
PostPosted: March 14th, 2008, 21:27
Do logical scan in DE or scan the image with R-Studio/GetDataBack.
PostPosted: March 15th, 2008, 9:57
Cool. Thanks!
Users browsing this forum: Google [Bot], shubhsinghal and 96 guests
