D540X-4K Head Replacement
December 18th, 2007, 1:19
Does anyone know what identifying numbers I need for a successful head transplant on a D540X-4K? This drive seems to be half Maxtor and half Quantum. I found a LE06A011-01-B but I'm not sure if its compatable. Thanks.
D540X-4k
GTLA: LE06A011-01-A
P/N: MX4K060H3
P/N 1: JP-012342-12541-16U-12U4
CT: 246B60055M1UR0
P/N 3: 11S06P5331ZJ1H9T3HEU14
FRU: 19K1581
S/N: 373117925924
Re: D540X-4K Head Replacement
December 18th, 2007, 14:23
this one is tricky, it is almost impossible to find a fully compatible MHA due to the different alignment positions of the heads.
All u can do is to match at least the first letter of the code bellow the serial number and hope or align the heads.
March 16th, 2008, 1:13
Ok. I transplanted the donor heads into the failed drive but now I have a new problem. The heads go from center to outer edge three times then stay on the outer edge. After that it reports ready but does not ID. Before the transplant I could read from head 0 and 2 but not 1. Any ideas? Thanks.
March 17th, 2008, 2:40
this is what I call head misalignment... with 60G it is pretty hard to get them aligned.
March 17th, 2008, 3:00
The donor was spot on as far as identification numbers and all. In fact, the serials are really close. Do you have any advise on aligning the heads? Thanks.
March 17th, 2008, 7:59
Ho There ,
Ask Pep sir About the Head Alignment Issue ,I Will Try To Find The Exact Numbers For you I Have 100 of These Drives even Pepe Sir Might Remember that .
March 17th, 2008, 22:19
Failed Drive: DGPXX
Donor Drive: DGZXX
March 19th, 2008, 11:11
What kind of clicking it had originally? Ding-ding-spinfaster-spinslower-ding-ding-ding? If yes then it's usually bad preamp and it's much easier to just swap it and keep the original heads.
March 19th, 2008, 14:15
Never clicked, just could not read from head 1. 0 and 2 work fine in DE.
