 Post subject: Western Digital data recovery
PostPosted: March 13th, 2008, 3:46
Hi All i have problem with Western Digital Sata Drive.which has clicking noise ,and data has to be recovered .any solution.
Thank you.
 Post subject: Re: Western Digital data recovery
PostPosted: March 13th, 2008, 4:47
Be more specific: What is the MDL line of this disc ? Its on the front sticker.
Does the clicking stops after some time or not ?
Dobre
Murphy was an optimist
PostPosted: March 13th, 2008, 4:49
Hi dobrevjetser
Model WD Caviar
SN WD-WMAM9H448996
it start and stop.
PostPosted: March 13th, 2008, 6:31
WD Caviar what ??? WD400BB-00FU0A or something like that.
Dobre
PostPosted: March 13th, 2008, 6:33
WD800
HDD S/N WD -WMAM9H448996
MDL WD800JD-75MSA1
80GB
THANKS.
PostPosted: March 13th, 2008, 9:57
Does it click about 5 times and then stops ?
Then probably the heads are bad.
Dobre
PostPosted: March 14th, 2008, 6:11
yes it clicks and stop.
PostPosted: March 14th, 2008, 7:18
Then you probably got a head/amp problem.
If your data is importent, give it to a local DR company.
Regards/ Bosse
http://www.rescue-it.se
Users browsing this forum: Google [Bot] and 72 guests
