Head Remover Tool
March 15th, 2008, 4:13
it's impossible to post a right way about head remover pls !
Re: Head Remover Tool
March 16th, 2008, 14:17
best head remover Hands !
March 19th, 2008, 12:41
You should first of all read a lot and try a lot. If you plan to do it quickly, most probably you'll fail a lot.
March 23rd, 2008, 20:15
indeed takes a lot of practice.
first time = fail
March 26th, 2008, 2:36
if the head is not damaged in anyway
remove the ic amp controller chip and replace with a working one.
your have to be careful when you do a head swap
as there a good chance you can damaged the platters at the same time.
allso you must keep the heads from touching each other.
