 Post subject: HD mechanical Failure
PostPosted: October 10th, 2004, 15:04
What equipment do you need to buy,
to repair hard drives with mechanical problems.
I have 50+ hard drives with mechanical failures.
Some off the dives are WD 120GB.
Thank You
Bob Whitman
xboomerx@yahoo.com
PostPosted: October 10th, 2004, 16:22
Screwdrivers T4..T10 and hands...
PostPosted: October 11th, 2004, 11:19
Screwdrivers T4..T10 and hands... and if that does work, a hammer is an alternate solution. :wink:
PostPosted: October 12th, 2004, 0:55
How do you know these are mechanical failures?
Heads are clicking? Drives are not spinning?
PostPosted: October 13th, 2004, 6:45
Money is no problem.
I will setup a clean room.
How do I setup a clean room?
What type of specialized equipment is required
and where do I buy the equipment?
I have another 100+ hard drives
that maynot have mechanical failures.
What is the best repair software?
Thank You
xboomerx
PostPosted: October 14th, 2004, 9:39
If money is not a problem, get yourself a Class 100 clean room and PC-3000.
Goog luck.
Tony.
PostPosted: October 17th, 2004, 9:19
perhaps factory commands can help you,or the pc3000 and hrt also can help you,but you have to learn for a long time .
PostPosted: October 29th, 2004, 20:06
Hello, I have lots of money. I want to start a professional data recovery company with many years of experience. What is a hard drive? Do I just need class 100 and PC3k and a set of Torx screw drivers :bebebe: :evil:
