 Post subject: WDC 7500AAKS CHS and LBA Issue
PostPosted: March 22nd, 2008, 10:05
Mates ,
this One Is the strangest Case ,I Have Two WDC Drives when I Connect The Same To My Motherboard A ASUS A8N-E Via Sata One Will Always Initialise In CHS Mode and the Other One in LBA Mode.I Have Having a Issue That the Motherboard Halts When i Try To Access The CHS HDD The LBa Works Fine .Why Cannot My Board Detect That Perticular HDD as LBA
 Post subject: Re: WDC 7500AAKS CHS and LBA Issue
PostPosted: March 23rd, 2008, 2:04
Amarbir,
Seems like a translator problem.
It can be rebuild with a PC3K from the P-List and G-list perhaps a bad translator would probably mean a defective Firmware cause by an overflow of bad sector so if you fix Translator you should not use this drive as a daily drive you should backup your data and replace it or Backup your data make a surface scan then move the G-List to P-List and reformat the drive.
Hope it helps
Francis Parent-Valiquette
http://www.tux-tech.ca/
PostPosted: March 23rd, 2008, 2:27
Nope ,
Something To Do With the Firmware Yes ,P And G Bad and Translator Issue Nope .Cos Both Are Brand NEw Drives But Purchased FRom diff People .The HDD Works Fine in diff Mboard Not The ASUS A8N-E :good:
PostPosted: March 23rd, 2008, 11:15
U have a prob with ur mboard
www.datarecoveryne.com
PostPosted: March 23rd, 2008, 15:24
Correct ,
Can You Explain why the Other SAme Model WDC 7500AAKS Gets Detected As LBA And Not the first One .the Board Remains The Same ,Its a Damn funny Situation .
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
PostPosted: March 23rd, 2008, 18:00
Hi, have you tryed to reflash your bios with a newer version....or set the default settings in bios?
Regards/ Bosse
http://www.rescue-it.se
PostPosted: March 23rd, 2008, 18:14
Regards/ Bosse
:mrgreen: come guys you know me i am not a nerd ,Thanks For Reminder though ,Its Latest 1013
