 Post subject: SAMSUNG problem on M/C SP0822N
PostPosted: March 25th, 2008, 14:21
Problem with a SP0822N : the M/C has error on 0/0/401 so can't SAVE the M/C and so H/T stops with an error. H/T is needed before B/I , but seems that I am in a dead end.
What should I try ? It's just an experiment, no need the data, no worry about destroying the drive. The drive has only bads on some zone , heads seem to be OK.
Just want to make this drive work again with a stable M/C.
Rewriting the modules from a backup works, buth the problem on the M/C is still there. This is a bit confusing....
Regards !
Users browsing this forum: Google [Bot] and 94 guests
