 Post subject: wd 40 always busy
PostPosted: March 25th, 2008, 19:35
hello guys.
I have a problem with wd400EB - 00CPF0.
I scanned it using mhdd and it is always BUSY.
I need help please.
thank u all
 Post subject: Re: wd 40 always busy
PostPosted: March 25th, 2008, 19:43
Hi
I should hear its sound uppon power up...
do u mean it doesn't even get out of BUSY after powering up?
PostPosted: March 26th, 2008, 2:33
when the hard drive spins up can you hear it
does it spin down or just keeps going
this sounds you got a faulty pcb board
might be open circuit on the power ic
but not to sure
PostPosted: March 26th, 2008, 6:06
thank u pepe and craig,
yes pepe it is not even get out of BUSY after powering up.
it doesn't complete the Recalibration sound.
I tried to change the PCB craig but nothing is happened.
thank u again friends
PostPosted: March 26th, 2008, 7:18
Hi
how much did u wait? Drive might need some minutes to pass badsectors in the SA... after that it should get ready.
PostPosted: March 26th, 2008, 9:21
Hi pepe
It is never get ready
I think it is SA problem
when i tried to press F2 to identify the hdd it is ( drive not ready NO DRSCE or DRDY )
Thanks for replying
PostPosted: March 26th, 2008, 13:24
Did u got IDNF or AMNF, ata register control errors? while tried to read any sector
Best Regards
PostPosted: March 26th, 2008, 16:05
hi beto
no I didn't got any errors the hdd still busy can not recieve DRSC or DRDY
thank u friend
PostPosted: March 26th, 2008, 16:47
When you swapped the PCB, did you try the donor PCB with & without the ROM?
A continuous BSY signal is a symptom of a corrupted ROM (among other things).
Jon
http://www.datasaversllc.com
PostPosted: March 26th, 2008, 17:01
hello jono
but i already tried diffrent PCBs and have the same problem
thank u
PostPosted: March 26th, 2008, 17:03
Is it maybe a PREAMP problem ?????????
PostPosted: March 26th, 2008, 21:56
^no. do you have the same drive? hot spaw.
PostPosted: March 27th, 2008, 8:28
hello grig85
I did this already but I have the same problem
thank u for ur help
PostPosted: March 27th, 2008, 11:11
Gee, I wonder if the motor is up to speed . . . .
PostPosted: March 28th, 2008, 11:52
BUSY means drive started the task and that task remains unfinished. bad micro code in SA, and your drive is trying to load with it. got PC3000?
PostPosted: March 28th, 2008, 13:40
Thank you grig
the answer for your last question is NO
I don't have one
thank you all friends
