 Post subject: Seagate Selfscan & Firmware result. Help needed
PostPosted: April 3rd, 2008, 13:36
Hi Experts,
Please find the corrected results of Firmware & Selfscan results.
For unknown reasons, I'm not able to delete my previous post which is unclear.
NEEDED EXPERTS/PROFESSIONALS ADVICE ON THIS PROBLEM.
THANKS IN ADVANCE.
Firmware Result
/T
T>
:50000000A1000001 AX`3HS8CM6S' "000000000000"7000-7028
ÿInterface task reset
1024k x 16 buffer detected
SNOWMASS - 1_Disk 3.75 11-20-01 13:27
Power Cycling
ATReset
Head Mask 0003 - Switch to full int.
Spin Ready
AutoRd Err 47 at 700c.00.0006
AutoRd Err 47 at 700c.00.0092
TPAge=50 Type=A1 MxCyl=DC91 MxHd=1 MxSct=068 BSz=0800 TCode=0000
Pgm=00 Trk=D104(D12D).0(1).005(004) Zn=B Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=00000000
((VALID Cert Disk Code Detected - Revision # 3.75
T>y
Command Inactive - No VALID Cert Code Detected
T>/2
2>x
Zone 0: 0015 - 17AF 833 552.156
Zone 1: 17B0 - 2FE0 833 552.156
Zone 2: 2FE1 - 40F0 833 552.156
Zone 3: 40F1 - 5700 784 510.588
Zone 4: 5701 - 696B 784 510.588
Zone 5: 696C - 7D00 718 477.647
Zone 6: 7D01 - 8B8B 686 454.117
Zone 7: 8B8C - 9B24 653 435.294
Zone 8: 9B25 - A9D6 616 414.117
Zone 9: A9D7 - BA00 588 385.882
Zone A: BA01 - C4BA 548 371.092
Zone B: C4BB - D105 522 352.941
Zone C: D106 - DC91 490 330.756
Sys= 7000-7028 02B9 SPTK on sys trks
Total LBAs = 04C66911
2>
Selfscan Result
>(Cert Table loaded
Begin Test 02
ASCII logging on
Not Power Cycling
Not Power Cycling
Zone 0 Head 0 adaptives set to defaults
Zone 0 Head 1 adaptives set to defaults
Zone 1 Head 0 adaptives set to defaults
Zone 1 Head 1 adaptives set to defaults
Zone 2 Head 0 adaptives set to defaults
Zone 2 Head 1 adaptives set to defaults
Zone 3 Head 0 adaptives set to defaults
Zone 3 Head 1 adaptives set to defaults
Zone 4 Head 0 adaptives set to defaults
Zone 4 Head 1 adaptives set to defaults
Zone 5 Head 0 adaptives set to defaults
Zone 5 Head 1 adaptives set to defaults
Zone 6 Head 0 adaptives set to defaults
Zone 6 Head 1 adaptives set to defaults
Zone 7 Head 0 adaptives set to defaults
Zone 7 Head 1 adaptives set to defaults
Zone 8 Head 0 adaptives set to defaults
Zone 8 Head 1 adaptives set to defaults
Zone 9 Head 0 adaptives set to defaults
Zone 9 Head 1 adaptives set to defaults
Zone A Head 0 adaptives set to defaults
Zone A Head 1 adaptives set to defaults
Zone B Head 0 adaptives set to defaults
Zone B Head 1 adaptives set to defaults
Zone C Head 0 adaptives set to defaults
Zone C Head 1 adaptives set to defaults
SkpCylList deleted
<empty>
drive must be reformatted
EP=1, TA=1, HiGain=1, OTRd=1, Early Rd=0, Splash=1, Reload=1, VCO=1, MRBias=1
Bst/Zap=1, SrvoThrsh=1, RunOut=1, MaxECC=1, ECC 2=1, ECC 1=1, ECC 0=1
Data=FF, Write=80, ID=FF
No entries in Log
Head Mask 0001 -
Read Bias - Head 0 1 2 3
B 7
HiTemp Bias Head 0 1 2 3
9 5
Switch to full int.
Spin Ready
All Hds 0-1, All Cyls 0015-DC91, Rnd data
EP=0, TA=0, HiGain=0, OTRd=0, Early Rd=0, Splash=0, Reload=0, VCO=0, MRBias=0
Bst/Zap=0, SrvoThrsh=0, RunOut=0, MaxECC=0, ECC 2=1, ECC 1=1, ECC 0=1
Data=02, Write=40, ID=1E
Napa Srvo Table
Head Addr Ctrl VGA SATT Tap5 Tap6 Tap3 Tap7 Tap2 Tap8 Tap9
00 FA06 50 70 E9 80 8E C8 86 13 B3 70
01 FA1A 50 70 E9 8D A1 D4 96 1A C6 7F
Adapt Servo Zone 07
Adapt Servo 9358.00
Adapts Loaded
Napa DATA load
Test 9358.00 0080b4c5 BER 0300186e
Adjust _ATT 01 VGAS 85 VGAR ab FREQR 7b Read 0047
MRASYM 80 1080e034 BER 03000529
MRASYM 80 1080dc61 BER 0300003d hold
Zone 7
[8BAC.0,FE49,0120,1c, 3] ->Min=07FF(FE49) BL=7FFF BR=7FFF Range=0000 Pick=FE49
[8BCC.0,FE49,0120,1c, 3] ->Min=07FF(FE49) BL=7FFF BR=7FFF Range=0000 Pick=FE49
[8BEC.0,FE49,0120,1c, 3] ->Min=07FF(FE49) BL=7FFF BR=7FFF Range=0000 Pick=FE49
[8BEC.0,FE49,0120, 1, 3] ->Min=01B6(FFCF) BL=7FFF BR=7FFF Range=0000 Pick=FFCF
Zone 8
[9B45.0,FE87,0180,1c, 3] ->Min=07FF(FE87) BL=7FFF BR=7FFF Range=0000 Pick=FE87
[9B65.0,FE87,0180,1c, 3] ->Min=07FF(FE87) BL=7FFF BR=7FFF Range=0000 Pick=FE87
[9B85.0,FE87,0180,1c, 3] ->Min=07FF(FE87) BL=7FFF BR=7FFF Range=0000 Pick=FE87
[9B85.0,FE87,0180, 1, 3] ->Min=0239(0052) BL=7FFF BR=7FFF Range=0000 Pick=0052
Test 9358.00 000149a4 BER 00000681
Zone 0
[0035.0,FB3D,FE25,1c, 3] ->Min=07FF(FB3D) BL=7FFF BR=7FFF Range=0000 Pick=FB3D
[0055.0,FB3D,FE25,1c, 3] ->Min=07FF(FB3D) BL=7FFF BR=7FFF Range=0000 Pick=FB3D
[0075.0,FB3D,FE25,1c, 3] ->Min=07FF(FB3D) BL=7FFF BR=7FFF Range=0000 Pick=FB3D
[0075.0,FB3D,FE25, 1, 3] ->Min=006F(FBE8) BL=7FFF BR=7FFF Range=0000 Pick=FBE8
Zone 1
[17D0.0,FC07,FECB,1c, 3] ->Min=07FF(FC07) BL=7FFF BR=7FFF Range=0000 Pick=FC07
[17F0.0,FC07,FECB,1c, 3] ->Min=07FF(FC07) BL=7FFF BR=7FFF Range=0000 Pick=FC07
[1810.0,FC07,FECB,1c, 3] ->Min=07FF(FC07) BL=7FFF BR=7FFF Range=0000 Pick=FC07
[1810.0,FC07,FECB, 1, 3] ->Min=0087(FC85) BL=7FFF BR=7FFF Range=0000 Pick=FC85
Test 178f.00 000105e3 BER 000000b3
RDBIAS Lower 03 Upper 0b Step 01 Right 08 Mask 2000
Default 0b 0001033d BER 0000008f
Floor 1 07 00010e2f 000201c6
Left 1 0b 00010e2f
Middle 1 0b 00010e2f
Right 1 0b 00010e2f
Lowest 1 0b 00010e2f
New 0b 00011245 BER 0000009d
Adjust _ATT 01 VGAS 85 VGAR 97 FREQR 86 Read 0043 SRVTEST e8 Read 0043
Adjust _ATT 00 VGAS 57 VGAR 6f FREQR 87 Read 0043 within _ATT
MRASYM 80 00015cd8 BER 0000033a
MRASYM 80 00015e53 BER 000004ff hold
Default Tap Weight 00000000 Settle Tap Weight 00000103
Adjust
CUTOFF Lower 30 Upper 60 Step 02 Right 18 Mask 0008
Default 5a 000072df BER 00000000
Floor 1 19 00007b22 00007b22
Left 1 32 000072a2
Middle 1 49 0000770a
Right 1 60 00007b14
Lowest 1 32 000072a2
New 49 000076da BER 00000000
TAPDELT Lower 05 Upper 0a Step 01 Right 05 Mask 0010
Default 06 00007931 BER 00000000
Floor 1 06 000077b9 0000790d
Left 1 08 000072bd
Middle 1 09 0000756f
Right 1 0a 000077b9
Lowest 1 08 000072bd
New 09 000074f2 BER 00000000
00007997 BER 00000000 _ATT 00 VGAS 59 VGAR 5b FREQR 7e Taps frozen read adapt
Current Tap Weight 000002ae diff fffffd52 tap limits
00007700 BER 00000000 _ATT 00 VGAS 56 VGAR 59 FREQR 7c Taps frozen read adapt
Current Tap Weight 00000087 diff 00000227 tap limits
00007805 BER 00000000 _ATT 00 VGAS 56 VGAR 5c FREQR 7e Taps frozen read adapt
Current Tap Weight 00000063 diff 00000024 Save servo Force servo update
Napa DATA load
Test 9358.00 00015911 BER 00000fff
Adapt Servo 9358.01
Adapts Loaded
Napa DATA load
Test 9358.01 00006bc8 BER 00000004
Adjust _ATT 01 VGAS 8a VGAR b2 FREQR 81 Read 0043 SRVTEST e8
Adjust _ATT 00 VGAS 5e VGAR 87 FREQR 7c Read 0043 SRVTEST e8
fail lower limit
Napa DATA load
Test 9358.01 00008b8f BER 00000013
Adapt Servo 9378.01
Adapts Loaded
Napa DATA load
Test 9378.01 00006d38 BER 00000000
Adjust _ATT 01 VGAS 8e VGAR b8 FREQR 8f SRVTEST e8 Read 0043
Adjust _ATT 00 VGAS 66 VGAR 84 FREQR 75 SRVTEST e8
fail lower limit
Napa DATA load
Test 9378.01 000066d1 BER 00000004
Adapt Servo 9398.01
Adapts Loaded
Napa DATA load
Test 9398.01 00006f14 BER 00000010
Adjust _ATT 01 VGAS 87 VGAR ad FREQR 7e Read 0043 SRVTEST e8
Adjust _ATT 00 VGAS 5f VGAR 8c FREQR 81 Read 0043 SRVTEST e8 Read 0043
fail lower limit
Napa DATA load
Test 9398.01 00006787 BER 00000000
Adapt Servo 93b8.01
Adapts Loaded
Napa DATA load
Test 93b8.01 000068b7 BER 00000000
Adjust _ATT 01 VGAS 8b VGAR ba FREQR 87 SRVTEST e8 Read 0043
Adjust _ATT 00 VGAS 5f VGAR 89 FREQR 72 SRVTEST e8
fail lower limit
Napa DATA load
Test 93b8.01 00006be1 BER 00000006
FAILED SERVO Zone 07 Head 01 Error 00cf
Zone 5
[698C.0,FDD4,0043,1c, 3] ->Min=07FF(FDD4) BL=7FFF BR=7FFF Range=0000 Pick=FDD4
[69AC.0,FDD4,0043,1c, 3] ->Min=07FF(FDD4) BL=7FFF BR=7FFF Range=0000 Pick=FDD4
[69CC.0,FDD4,0043,1c, 3] ->Min=07FF(FDD4) BL=7FFF BR=7FFF Range=0000 Pick=FDD4
[69CC.0,FDD4,0043, 1, 3] ->Min=00AB(FEC7) BL=7FFF BR=7FFF Range=0000 Pick=FEC7
Zone 6
[7D21.0,FE0F,0074,1c, 3] ->Min=07FF(FE0F) BL=7FFF BR=7FFF Range=0000 Pick=FE0F
[7D41.0,FE0F,0074,1c, 3] ->Min=07FF(FE0F) BL=7FFF BR=7FFF Range=0000 Pick=FE0F
[7D61.0,FE0F,0074,1c, 3] ->Min=07FF(FE0F) BL=7FFF BR=7FFF Range=0000 Pick=FE0F
[7D61.0,FE0F,0074, 1, 3] ->Min=0389(FF50) BL=7FFF BR=7FFF Range=0000 Pick=FF50
Zone 5
[698C.1,FDD4,0043,1c, 3] ->Min=0000(FEA3) BL=FE8E BR=FECD Range=0040 Pick=FEAE
Zone 6
[7D21.1,FE0F,0074,1c, 3] ->Min=0000(FF32) BL=FF29 BR=FF5F Range=0037 Pick=FF44
HiTemp Bias BackOff Head 0 1 2 3
9 5
Napa Srvo Table
00 FA06 50 5C E8 7B 90 C6 82 18 B8 6A
Adapt Data Zone 05
Adapt Data 7336.00
Napa DATA load
Test 698c.00 00011301 BER 0000014b
Test 7336.00 000124ba BER 0200017a
Check _ATT 00 VGAS 5c VGAR 86 FREQR 80 Read 0043 within VGAR FREQR
MRASYM 80 00012733 BER 01000192
MRASYM 81 0001259c BER 010001a4 update 81 hold
OD OFST Lower fe67 Upper ff26 Step 0007 Right 1b Mask 4340
Default fec7 000113d2 BER 00000121
Floor 1 09 000158da 000158da
Left 1 fea6 000132f7
Middle 1 febc 0000ef81
Right 1 fed2 000152d6
Lowest 1 febb 0000ef81
New febc 0000f55e BER 000000f3 AUTO
Check _ATT 00 VGAS 5b VGAR 71 FREQR 7b Read 0043 within VGAR FREQR
Test 7336.00 000110cd BER 00000179
Noise target 00000000
Napa Noise OFF
WRITE_I Lower 00 Upper 15 Step 01 Right 15 Mask 0342
Default 10 0001f1db BER 01000283
Floor 1 0c 000150cf 000150cf
Left 1 0c 00014e90
Middle 1 10 00010922
Right 1 15 0000f4b4
Lowest 1 14 0000e94a
New 10 000113d5 BER 000001e8 AUTO
MRASYM 81 0001141b BER 00000209
MRASYM 81 000231db BER 010003de hold
Test 7336.00 00010464 BER 00000147
PRECOMP Lower 00 Upper 0a Step 01 Right 0a Mask 0004
Default 00 00011852 BER 0000013c
Floor 1 0b 0000fc16 0000fc16
Left 1 01 0000f103
Middle 1 05 0000f649
Right 1 09 0000e946
Lowest 1 08 0000e5e2
New 05 0000e791 BER 000000ca
CUTOFF Lower 7a Upper da Step 04 Right 18 Mask 0348
Default a2 0000e8f0 BER 000000ce
Floor 1 18 00012bf3 00012bf3
Left 1 8e 00011b2c
Middle 0 b4 00011490
Right 1 da 00012091
Lowest 1 aa 0000ea5f
Restore a2 0001107a BER 010000d8
TAPDELT Lower 00 Upper 0f Step 01 Right 0f Mask 0350
Default 08 0000e6e8 BER 000000a9
Floor 1 10 0001ceec 0001ceec
Left 1 03 00019b1f
Middle 1 08 0000f1bd
Right 1 0e 0001c4cc
Lowest 1 07 0000e55f
New 08 0000ed9c BER 000000cb
BOOST Lower 02 Upper 2f Step 02 Right 16 Mask 0360
Default 07 000109e2 BER 00000119
Floor 1 06 00011581 00011581
Left 1 06 00010fc9
Middle 1 08 00010532
Right 1 0b 00010c5b
Lowest 1 08 00010532
New 08 0000efd2 BER 000000c5 AUTO
OD OFST Lower fe9f Upper fed9 Step 0002 Right 1d Mask 4340
Default febc 000100cd BER 000000f4
Floor 1 1d 000153f8 000153f8
Left 1 fea5 00013e96
Middle 1 feba 0000fa38
Right 1 fecf 00014de8
Lowest 1 feb3 0000f952
New feba 0000f82b BER 000000f0 AUTO
CUTOFF Lower 8a Upper da Step 03 Right 1a Mask 0348
Default a2 0000f52f BER 00000111
Floor 1 1b 000109c2 000109c2
Left 1 90 00010746
Middle 1 aa 0000f910
Right 1 c5 00010989
Lowest 1 9c 0000ef17
New aa 0000f52a BER 00000100 AUTO
TAPDELT Lower 02 Upper 0f Step 01 Right 0d Mask 0350
Default 08 0000f43c BER 000000fc
Floor 1 0e 00019df5 00019df5
Left 1 03 000188a6
Middle 1 08 0001c8de
Right 1 0d 000152d8
Lowest 1 07 0000f212
New 08 0000fc81 BER 00000139
BOOST Lower 04 Upper 0d Step 01 Right 09 Mask 0360
Default 08 00015428 BER 0000028e
Floor 1 09 00018fc9 00018fc9
Left 1 06 0001732b
Middle 1 08 00015487
Right 1 0b 000133e9
Lowest 1 0b 000133e9
New 08 0000f0e8 BER 000000be AUTO
Napa Noise OFF
Check _ATT 00 VGAS 5d VGAR 75 FREQR 80 Read 0043 within VGAR FREQR
MRASYM 81 0000f73a BER 000000bd
MRASYM 82 0000eded BER 0000023d update 82 adapt
Test 7336.00 0000dcad BER 000000c9
BETTER UPDATE TAPS Napa DATA save
Media 0000
Adapt Data 7336.01
Napa DATA load
Test 698c.01 00002b5b BER 00000000
Test 7336.01 000033f6 BER 00000000
Check _ATT 01 VGAS 8f VGAR a5 FREQR 7d within VGAR FREQR
MRASYM 80 00003757 BER 00000000
MRASYM 79 000036c9 BER 00000000 update 79 hold
OD OFST Lower fe4e Upper ff0d Step 0007 Right 1b Mask 4340
Default feae 00002bdc BER 00000000
Floor 1 11 000057f2 000057f2
Left 1 fe7f 000056c2
Middle 0 feaa 00002db8
Right 1 fed5 000057aa
Lowest 1 fea2 00002c9b
Restore feae 00002bf3 BER 00000000
Check _ATT 01 VGAS 8e VGAR aa FREQR 7a within VGAR FREQR
Test 7336.01 000037ca BER 00000000
Napa Noise OFF
Default 10 0000377c BER 00000000
Floor 1 16 00004372 00004372
Left 1 00 00003931
Middle 1 0a 00003d0e
Right 1 15 000038a6
Lowest 1 0b 000033d0
New 0a 00003656 BER 00000000 AUTO
MRASYM 79 00003c28 BER 00000000
MRASYM 76 0000379e BER 00000000 update 76 hold
Test 7336.01 00003569 BER 00000000
Default 00 000034d5 BER 00000000
Floor 1 0b 00003703 00003d73
Left 1 00 00003703
Middle 1 02 00003580
Right 1 04 00003703
Lowest 1 01 000034b3
New 02 00002fdb BER 00000000
Default a2 000031ba BER 00000000
Thanks in advance,
RDS.
Users browsing this forum: No registered users and 61 guests
