 Post subject: Cloning drives with physical problems
PostPosted: April 9th, 2008, 3:01
:( Please tell me, which is the best way to clone a dying Hard drive to another good one.
 Post subject: Re: Cloning drives with physical problems
PostPosted: April 9th, 2008, 3:57
A drive with physical problems, before you image it, you have to fix it's problems.
PostPosted: April 9th, 2008, 13:06
The best its did a good diagnostic, the most important its not tried to undestando how a tool works, the most important on my humble opinion its how a hdd works before u start to works on x hdd after u figure out what´s happening wich x hdd´s wich is the cause then u got all the points to get data back :D
not all the time but on the most cases
Best Regards
PostPosted: April 9th, 2008, 22:52
Depends on what failed. on bigger drives you can recover data with 1 failed head if its something small like a doc file without replacing heads.
PostPosted: April 10th, 2008, 4:53
if the hard drive is dying, try to finish your backup on another disk before its last breath;
if it's dead,try to bring it back to life with help of HD Doctor.
Or you can give us more symptoms of your hdd.
good luck and regards,
Laura Lee
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: April 11th, 2008, 8:18
I tried to clone it using HDD Clone but it gave me nothing, i tried HD Doctor (Salvation Data) but the seems not want to come back,
p.s Laura Lee your HD Doctor refused to work, I can load the drive on the HDD Management but after that the drive stops spinning. So practically there is nothing i can do with HDD Doctor. It's a seagate drive 40GB Model ST3400014a.
Users browsing this forum: Google [Bot] and 75 guests
