 Post subject: Files get distorted after copying to the hard drive
PostPosted: May 3rd, 2008, 3:55
Hi all,
recently I bought a Samsung HM160HI Spinpoint M hard drive in external usb case.
However, all the pictures/movies I store there get distorted (changed colors, strange stripes appear throughout). I did a low level format using "Hard Disk Low Level Format Tool" by HDDGURU. Then I formatted into NTFS using Partition Manager. However, I still have the same problem.
Do you think there is some way to fix this or the hard drive is defective...
Thanks!
 Post subject: Re: Files get distorted after copying to the hard drive
PostPosted: May 3rd, 2008, 10:08
Try the drive connected directly to the motherboard. I won't be the least surprised if you find your USB enclosure, or the USB cable, is mangling your data.
PostPosted: May 3rd, 2008, 11:15
hm, I guess you're right. I just opened the case and indeed it's really really crappy. I can't test it though, since I only have my notebook, which has another type of harddrive. I guess I'll buy another case.
thanks for the hint!
Users browsing this forum: Google [Bot] and 102 guests
