 Post subject: ST9120822AS problem. Need help
PostPosted: April 19th, 2008, 10:16
Dears,
I have a big problem with ST9120822AS. I suspect head problem, because it is knocking.
Terminal says:
VENUS - 1_Disk M-37 12-01-06_14:56
Buzz HM FREG701 88
HM FREG701 88
Unfortunately it has very rare FW: 3.CLF. I looked for it almost everywhere but no results.
So I decided to swap head from the same model but different FW: 3.ACL. The drive does not knock now but it can not be detected and terminal says now:
Buzz HM SFI
$($06DA7,00E74,0000,00,19,70,71)REG701 91
HM SFI
$($1338D,00E74,0000,00,8B,30,08)
I suspect that firmware incompatibility is the problem.
Could you advise me what can I do now? Do you have any idea how to overcome this problem?
I consider to re-solder ROM chip but I am not sure.
Thank you very much for any help.
Regards,
Rafael
 Post subject: Re: ST9120822AS problem. Need help
PostPosted: April 19th, 2008, 11:57
Hello wich site code its your patient and donnor?
Best Regards
PostPosted: April 19th, 2008, 13:30
both are the same: WU.
Rafael
PostPosted: April 20th, 2008, 23:32
i think your drive come from MACBOOK.
Forget about it friend. The media got damage already.
Спасибо
СУТИОНО / АПИНГ
PostPosted: April 21st, 2008, 3:26
Prodata,
the disk is from Lenovo notebook, so it has standard Windows OS.
Does my chance grow up?
Regards,
Rafael
PostPosted: April 21st, 2008, 4:46
from your termiinal report.
head already dead.
this 120 GB got 2 platter with 3 head. probably one of its head already dead. due to platter damaged.
Спасибо
СУТИОНО / АПИНГ
PostPosted: April 21st, 2008, 5:30
Dear prodata,
yes, I completely agree with you, but how can I overcome the problem with no compatible donor?
Regards,
Rafael
Users browsing this forum: Google [Bot], pepe and 49 guests
